Creating autocad automization
Jef_E
Jef_E
I'm new to autocad automization, and by new I mean no knowledge what so ever. I do have some experience with Autodesk Inventor Customization.
What I am asking is where do I start? Is there a API that I can read for samples? Any good tutorials?
The application I would like to make is a standalone executable program that creates a block from the selection and scales it to value x in one direction. At the end the block will be exploded.
Some advice would be awesome!!
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Jef_E
I'm going to try this link
Inventor 2014 SP2
Alexander.Rivilis
@Jef_E wrote:
...The application I would like to make is a standalone executable program that creates a block from the selection and scales it to value x in one direction. At the end the block will be exploded...
As far as it will be standalone executable program (exe-file) - so you have to use AutoCAD ActiveX Interface.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
dgorsman
Driving AutoCAD from an external EXE doesn't have many benefits, and a number of restrictions.  Normal operation is to create something that operates *inside* the  AutoCAD session, whether its a dotNET DLL plug-in, ObjectARX ARX application, or a LISP routine.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Jef_E
I was looking into ObjectARX, but if I understand correct this is not compatible for AutoCad-LT? Are there other methods to create my described tool that are compatible with AutoCad and AutoCad-LT?
Inventor 2014 SP2
norman.yuan
If your "AutoCAD Customization" target is AutoCAD LT, you are out of luck: AutoCAD LT cannot be customized programmatically. You need full AutoCAD.
Norman Yuan
Drive CAD With Code
