creating a line between two points
All I have done till now is quite basic VB.net stuff
I would like to get more advanced and creative with my creations. basically when i think AutoCAD i think lines so a nice short program to get started with is to create a line between two point (or simular). The tutorials online are wofel in learning the basics such as this is anyone out there able to give me a few starters on how to achive this
norman.yuan
Have you gone through Autodesk provided .NET programming labs? Have you gone through AutoCAD .NET Developer's Guid online (http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html)?
Anyway, here's some quick code (without actually running/testing in VS):
Dim pt1 As New Point3d(0.0,0.0,0.0)
Dim pt2 As New Point3d(1.0,1.0,0.0)
''A new line entity is created
Dim myLime As New Line(pt1, pt2)
''Set the line's properties,such as layer, linetype...to default
myLine.SetDatabaseDefault()
''Do something with the line
''If you do not want to add it to the current drawing database,
''you need to dispose it after you done whth it
'myLine.Dispose()
''Add it to current drawing database, modelspace
Dim db As Database=HostApplicationServices.WorkingDatabase
Using tran as Transaction=db.TransactionMananer.StartTransaction()
  ''Open Block Table
  Dim bt As BlockTable=tran.GetObject(db.BlockTableId,OpenMode.ForRead)
  ''Open modelspace
  Dim model As BlockTableRecord=tran.GetObject(bt(BlockTablerecord.ModeSpace),OpenMode.ForWrite)
  ''Add myLine to ModelSpace
  mode.AppendEntity(myLine)
  ''register the new entity with the transaction
  tran.AddNewLyCreatedDbObject(myLine,True)
  ''Complete the transaction
  tran.Commit()
End Using
HTH
Norman Yuan
Drive CAD With Code
chiefbraincloud
I suggest Kean Walmsley's blog.  He has been posting for almost 5 years know, and there is a wealth of information in the archives.
the first post is here:
http://through-the-interface.typepad.com/through_the_interface/2006/06/welcome.html
Jerry Winters has a good book on vb.net programming. Also Autocad University Online has tons of information and tutorials.
Dave
mgorecki
I'm just learning too.  This is what I use.
CreateLines(lineStartPt, lineEndPt, linetypeName)
Public Sub CreateLines(ByVal startPoint As Point3d, ByVal endPoint As Point3d, ByVal linetypeName As String)
        ' Get the current document and database
        Dim podDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim podCurDb As Database = podDoc.Database
        ' Start a transaction
        Using podTrans As Transaction = podCurDb.TransactionManager.StartTransaction()
            ' Open the Linetype table for read
            Dim acLineTypTbl As LinetypeTable
            acLineTypTbl = podTrans.GetObject(podCurDb.LinetypeTableId, OpenMode.ForRead)
            ' If the linetype has not been loaded, then load it
            If acLineTypTbl.Has(linetypeName) = False Then
                '' Load the Center Linetype
                podCurDb.LoadLineTypeFile(linetypeName, "acad.lin")
            ' Open the Block table for read
            Dim podBlkTbl As BlockTable
            podBlkTbl = podTrans.GetObject(podCurDb.BlockTableId, OpenMode.ForRead)
            ' Open the Block table record Model space for write
            Dim podBlkTblRec As BlockTableRecord
            podBlkTblRec = podTrans.GetObject(podBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            ' Create the lines
            Dim newLine As New DatabaseServices.Line(startPoint, endPoint)
            newLine.SetDatabaseDefaults()
            Select Case linetypeName
                Case "Continuous"
                    newLine.Linetype = "Continuous"
                Case "Dashed"
                    newLine.Linetype = "Dashed"
                Case "Phantom"
                    newLine.Linetype = "Phantom"
            End Select
            podBlkTblRec.AppendEntity(newLine)
            podTrans.AddNewlyCreatedDBObject(newLine, True)
            ' Save the changes and dispose of the transaction
            podTrans.Commit()
        End Using
    End Sub
