Creating a dxf with umlauts in text
c_hoppen
c_hoppen
I have a dxf that comes from Inventor and I need to add a text.
When I open the dxf in Mechanical 2024, umlauts are displayed incorrectly:
My first thought was that it had something to do with the Encoding.
So I created a new dxf in AutoCAD with just one text and opened it in notepad++.
It looks like this (created by AutoCAD)
I read and write my dxf with "UTF-8 without BOM"
Encoding utf8WithoutBom = new UTF8Encoding(encoderShouldEmitUTF8Identifier: false);
List<string> inhalt = System.IO.File.ReadLines(dxfdatei, utf8WithoutBom).ToList();
System.IO.File.WriteAllLines(dxfdatei, inhalt, utf8WithoutBom);
This is what my dxf looks like:
Nevertheless, the umlauts are displayed incorrectly, see picture at the top.
I have no idea which magic word I'm missing.
Thanks for help,
Christoph
Alfred.NESWADBA
in most cases no need to change the DXF ascii settings, instead choose the correct font/text style.
If you would upload the DXF we might try it.
'- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
c_hoppen
Alfred,
Thanks for help.
It turned out to be a version problem. The export format in Inventor (2025! ) was set to dxf 2004. Using dxf 2018 instead solved the problem.
I didn't have this problem with earlier versions of Inventor, so it's probably a problem with Inventor rather than Autocad.
Regards
Christoph
Alfred.NESWADBA
thank you for your feedback, good to know it's solved.
Well, I don't know Inventor, however I assume the DXF-Version setting was not set by Inventor, but instead from a user that does it.
It would be strange if any Autodesk software would export to such an old format by default 😉
'- alfred -
Alfred NESWADBA
