Create Regions
Create Regions
ashrafa33
Message 1 of 9
Create Regions
ashrafa33
I have more than 1000 polyline
when icreate REGION using regions = Region.CreateFromCurves(curves);
i get "Autodesk.AutoCAD.Runtime.Exception: eInvalidInput"
how i can Know where is my error
i want to know where i have open region or self-intersection
i think it is open or self-intersection less than 0.001 m
i wnat to find this point
Replies (8)
Message 2 of 9
hosneyalaa
@ashrafa33
try
 try
           /// code
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
https://forums.autodesk.com/t5/net/region-from-3d-polyline/m-p/10759703
Message 3 of 9
ashrafa33
i try it before
try catch give me
 Autodesk.AutoCAD.Runtime.Exception: eInvalidInput at
Autodesk.AutoCAD.DatabaseServices.Region.CreateFromCurves(DBObjectCollection
curveSegments)
at select.Select_Polylines.region_create() in .................:line 1050
it dose not give me where it is open or self-intersection
Message 4 of 9
ashrafa33
my polylines was arcs & line i convert them polylines list
to delete duplicted  and laping items then i try to make region
so they are not closed polylines
Message 5 of 9
hosneyalaa
Message 6 of 9
ashrafa33
the above post did not help me
any ideas
Message 7 of 9
ashrafa33
Message 8 of 9
hosneyalaa
Try to join lines and arc  Get polyline through Comment join
Does it work?
You must attached example drawing
And some code
Maybe you have a double in vertex ?
Message 9 of 9
SENL1362
Or arc's where the Tangents do not match the other end.
Seen these errors a lot for imported DXF files where the tangents of the rounded corners of rectangles have small rounding error (e.q. 89.9999 degrees).
Solution: Move these open endpoints en then move them back to the closing point.
