Create pdf which contain multiple layout in C#
Hello
I am trying to create pdf which contain all open layout sheet in C#
I have tried multiple solution but not getting output.
please help me
Thank you
_gile
You can try this one:
http://www.theswamp.org/index.php?topic=31897.msg494504#msg494504
Gilles Chanteau
GileCAD
GitHub
Thank you ,
I have referred your code in the link but at plotter.publish(); it throw an exception as (Inner exception:-> Operation is not valid due to the current state of objects. message:->exception has been thrown by the target of invocation.)
I have attached 2 screenshot to show where is exact exception thrown.
Hello
still I have not found any solution to plot open sheet into single pdf.
please help me to get it done.
Thank you.
waseefur.rahman
Just by sending the command in Command line, all layout will be created in PDF.
Try below code:
Public ReadOnly Property ThisDrawing() As AcadDocument  ' This is neccesary to use the VBA commands
Get
Return Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument)
End Get
End Property
ThisDrawing.Save()
ThisDrawing.SendCommand("FILEDIA" + vbCr & "0" + vbCr)
ThisDrawing.SendCommand("-EXPORT" & vbCr & "PDF" & vbCr & "ALL" & vbCr & "D:\" & vbCr)
ThisDrawing.SendCommand("FILEDIA" + vbCr & "1" + vbCr)
