Create PDF File from some Layouts only
Message 1 of 16
hello everybody
get an fatal error when  to try to plot ,mulitiple layouts in multiple files
i detect the format of the drawing and make from there my plot to pdf
  <CommandMethod("PUB1")> _
    Public Shared Sub Publish1()
        Dim openfdail As New OpenFileDialog("Select Drawings", Nothing, "dwg; dwf; *", "selfile", OpenFileDialog.OpenFileDialogFlags.AllowMultiple)
        Dim dr1 As System.Windows.Forms.DialogResult = openfdail.ShowDialog()
        If dr1 = System.Windows.Forms.DialogResult.OK Then
            Dim filenames() As String = openfdail.GetFilenames
            Dim file As String
            Dim filename As String = String.Empty
            Dim plotdir As String = "c:\plot\"
            Dim formaat As String = String.Empty
            ' Get the current document and database, and start a transaction
            Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = acDoc.Editor
            Dim oldDb As Database = HostApplicationServices.WorkingDatabase
            For Each file In filenames
                filename = System.IO.Path.GetFileNameWithoutExtension(file)
                'Check if drawing is a reference file if so dont plot
                If UCase(Mid(filename, 8, 1)) <> "R" Then
                    Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("BACKGROUNDPLOT", 0)
                    Using db As New Database(False, True)
                        db.ReadDwgFile(file, FileOpenMode.OpenForReadAndAllShare, False, Nothing)
                        db.CloseInput(True)
                        HostApplicationServices.WorkingDatabase = db
                        Using acTrans As Transaction = db.TransactionManager.StartTransaction()
                            Try
                                Dim ldic As DBDictionary = CType(acTrans.GetObject(db.LayoutDictionaryId, OpenMode.ForWrite), DBDictionary)
                                For Each entr As DictionaryEntry In ldic
                                    Dim lo As Layout = CType(acTrans.GetObject(entr.Value, OpenMode.ForWrite), Layout)
                                    If InStr(UCase(lo.LayoutName), "MODEL") = 0 Then
                                        If getform(acDoc, lo.LayoutName, db, ed) <> "LEEG" Or getform(acDoc, lo.LayoutName, db, ed) <> "ONBEKEND" Then
                                            LayoutManager.Current.CurrentLayout = lo.LayoutName
                                            filename = plotdir & System.IO.Path.GetFileNameWithoutExtension(file) & "." & lo.LayoutName & ".pdf"
                                            MsgBox(filename & " : " & LayoutManager.Current.CurrentLayout)
                                            MsgBox(db.OriginalFileName)
                                            plot(lo, db, acDoc, filename, file, ed)
                                Next
                            Catch ex As System.Exception
                                ed.WriteMessage(ex.ToString())
                            End Try
                        End Using
                    End Using
                HostApplicationServices.WorkingDatabase = oldDb
            Next
    End Sub
    Public Shared Sub plot(ByVal lo As Layout, ByVal db As Database, ByVal acdoc As Document, ByVal filename As String, ByVal file As String, ByVal ed As Editor)
        ' Get the PlotInfo from the layout
        Using acPlInfo As New PlotInfo()
            acPlInfo.Layout = lo.ObjectId
            ' Get a copy of the PlotSettings from the layout
            Using acPlSet As New PlotSettings(lo.ModelType)
                acPlSet.CopyFrom(lo)
                ' Update the PlotSettings object
                Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
                ' Set the plot type
                acPlSetVdr.SetPlotType(acPlSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents)
                ' Set the plot scale
                acPlSetVdr.SetUseStandardScale(acPlSet, True)
                acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit)
                ' Center the plot
                acPlSetVdr.SetPlotCentered(acPlSet, True)
                acPlInfo.OverrideSettings = acPlSet
                ' Specify if plot styles should be displayed on the layout
                acPlSet.ShowPlotStyles = True
                acPlSetVdr.RefreshLists(acPlSet)
                ' Set the plot style
                'acPlSetVdr.SetCurrentStyleSheet(acPlSet, "acad.ctb")
                acPlSetVdr.SetCurrentStyleSheet(acPlSet, "Zwart (kleur onderhoek).ctb")
                formaat = getform(acdoc, lo.LayoutName, db, ed)
                ' Set the plot device to use
                acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", formaat)
                ' Set the plot info as an override since it will
                ' not be saved back to the layout
                ' Validate the plot info
                Using acPlInfoVdr As New PlotInfoValidator()
                    acPlInfoVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled
                    acPlInfoVdr.Validate(acPlInfo)
                    ' Check to see if a plot is already in progress
                    If PlotFactory.ProcessPlotState = ProcessPlotState.NotPlotting Then
                        Using acPlEng As PlotEngine = PlotFactory.CreatePublishEngine()
                            ' Track the plot progress with a Progress dialog
                            Using acPlProgDlg As New PlotProgressDialog(False, 1, True)
                                Using (acPlProgDlg)
                                    ' Define the status messages to display
                                    ' when plotting starts
                                    acPlProgDlg.PlotMsgString(PlotMessageIndex.DialogTitle) = _
        "Plot Progress"
                                    acPlProgDlg.PlotMsgString(PlotMessageIndex.CancelJobButtonMessage) = _
        "Cancel Job"
                                    acPlProgDlg.PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage) = _
                                                              "Cancel Sheet"
                                    acPlProgDlg.PlotMsgString(PlotMessageIndex.SheetSetProgressCaption) = _
                                                              "Sheet Set Progress"
                                    acPlProgDlg.PlotMsgString(PlotMessageIndex.SheetProgressCaption) = _
        "Sheet Progress"
                                    ' Set the plot progress range
                                    acPlProgDlg.LowerPlotProgressRange = 0
                                    acPlProgDlg.UpperPlotProgressRange = 100
                                    acPlProgDlg.PlotProgressPos = 0
                                    ' Display the Progress dialog
                                    acPlProgDlg.OnBeginPlot()
                                    acPlProgDlg.IsVisible = True
                                    ' Start to plot the layout
                                    acPlEng.BeginPlot(acPlProgDlg, Nothing)
                                    ' Define the plot output
                                    acPlEng.BeginDocument(acPlInfo, _
                                                          acdoc.Name, _
                                                          Nothing, _
                                                          1, _
                                                          True, _
                                                          filename)
                                    ' Display information about the current plot
                                    '' Display information about the current plot
                                    acPlProgDlg.PlotMsgString(PlotMessageIndex.Status) = _
        "Plotting: " & file & _
        " - " & lo.LayoutName
                                    ' Set the sheet progress range
                                    acPlProgDlg.OnBeginSheet()
                                    acPlProgDlg.LowerSheetProgressRange = 0
                                    acPlProgDlg.UpperSheetProgressRange = 100
                                    acPlProgDlg.SheetProgressPos = 0
                                    ' Plot the first sheet/layout
                                    Using acPlPageInfo As New PlotPageInfo()
                                        acPlEng.BeginPage(acPlPageInfo, acPlInfo, True, Nothing)
                                    End Using
                                    acPlEng.BeginGenerateGraphics(Nothing)
                                    acPlEng.EndGenerateGraphics(Nothing)
                                    ' Finish plotting the sheet/layout
                                    acPlEng.EndPage(Nothing)
                                    acPlProgDlg.SheetProgressPos = 100
                                    acPlProgDlg.OnEndSheet()
                                    ' Finish plotting the document
                                    acPlEng.EndDocument(Nothing)
                                    ' Finish the plot
                                    acPlProgDlg.PlotProgressPos = 100
                                    acPlProgDlg.OnEndPlot()
                                    acPlEng.EndPlot(Nothing)
                                End Using
                            End Using
                        End Using
                End Using
            End Using
        End Using
    End Sub
    Shared Function getform(ByVal acdoc As Document, ByVal layout As String, ByVal db As Database, ByVal ed As Editor) As String
        Dim acTypValondnew(17) As TypedValue
        acTypValondnew.SetValue(New TypedValue(DxfCode.Operator, "<And"), 0)
        acTypValondnew.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 1)
        acTypValondnew.SetValue(New TypedValue(DxfCode.Operator, "<or"), 2)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF0a0"), 3)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF1a0"), 4)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF2a0"), 5)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF0a1"), 6)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF1a1"), 7)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF0a2"), 8)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF0a3"), 9)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF0a4"), 10)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF3a4"), 11)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF4a4"), 12)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF5a4"), 13)
        acTypValondnew.SetValue(New TypedValue(DxfCode.BlockName, "HTCAF6a4"), 14)
        acTypValondnew.SetValue(New TypedValue(DxfCode.Operator, "or>"), 15)
        acTypValondnew.SetValue(New TypedValue(DxfCode.LayoutName, layout), 16)
        acTypValondnew.SetValue(New TypedValue(DxfCode.Operator, "And>"), 17)
        Dim acSelFtrondnew As SelectionFilter = New SelectionFilter(acTypValondnew)
        Dim acSSPromptondnew As PromptSelectionResult
        acSSPromptondnew = ed.SelectAll(acSelFtrondnew)
        If acSSPromptondnew.Status = PromptStatus.OK Then
            Dim acSSet As SelectionSet = acSSPromptondnew.Value()
            Using actrans As Transaction = db.TransactionManager.StartTransaction()
                For Each acSSObj As SelectedObject In acSSet
                    Dim blkref As BlockReference = actrans.GetObject(acSSObj.ObjectId, OpenMode.ForRead)
                    Select Case blkref.Name
                        Case "HTCAF0a0"
                            formaat = "ISO_full_bleed_A0_(841.00_x_1189.00_MM)"
                        Case "HTCAF1a0"
                            formaat = "ISO_full_bleed_1A0_(841.00_x_1568.00_MM)"
                        Case "HTCAF2a0"
                            formaat = "ISO_full_bleed_2A0_(841.00_x_1758.00_MM)"
                        Case "HTCAF0a1"
                            formaat = "ISO_full_bleed_A1_(841.00_x_594.00_MM)"
                        Case "HTCAF1a1"
                            formaat = "ISO_full_bleed_1A1_(1189.00_x_594.00_MM)"
                        Case "HTCAF0a2"
                            formaat = "ISO_full_bleed_A2_(594.00_x_420.00_MM)"
                        Case "HTCAF0a3"
                            formaat = "ISO_full_bleed_A3_(420.00_x_297.00_MM)"
                        Case "HTCAF0a4"
                            formaat = "ISO_full_bleed_A4_(210.00_x_297.00_MM)"
                        Case "HTCAF3a4"
                            formaat = "ISO_full_bleed_3A4_(594.00_x_297.00_MM)"
                        Case "HTCAF4a4"
                            formaat = "ISO_full_bleed_4A4_(841.00_x_297.00_MM)"
                        Case "HTCAF5a4"
                            formaat = "ISO_full_bleed_5A4_(1050.00_x_297.00_MM)"
                        Case "HTCAF6a4"
                            formaat = "ISO_full_bleed_6A4_(1260.00_x_297.00_MM)"
                        Case Else
                            formaat = "ONBEKEND"
                    End Select
                Next
            End Using
        Else
            formaat = "LEEG"
        Return formaat
    End Function
Replies (15)
Message 2 of 16
BKSpurgeon
Hi Jorge
  • where is the error breaking?
  • What is the error you are getting?
It's a lot of code to sift through without much idea of  what it could be - make it easy for me to help you!
regards
BK
Message 3 of 16
hi BKSpurgeon
just get a fatal error and thats it
FATAL ERROR:  Unhandled Access Violation Reading 0xffb41988 Exception at dff1efa6h
i almost think i go wrong when i change file of the database
is one of the first experience with working only the database and trying to plot all the layouts
maybe i am thinking  all wrong
but thank u for ur reply and sorry i cant be more help
Message 4 of 16
Just my penny: I have no problem plotting multiple drawing, even plotting multiple layouts at once, but I've always loaded them as document, never tried to read just the db...
I'd try to load them as proper document and see if you still get the fatal error...
Message 5 of 16
BKSpurgeon
(1) Enclose the code in a try/catch command.
(2) We want the stack trace:
Try
//// put all your code here
catch
(MyCustomException ex) { Debug.Writeline(ex.ToString());
// we want to see what is printed out............this will show you the error line where the code breaks.
(3) Please try debugging and keep going till it breaks. could be anywhere.
Message 6 of 16
hi all thanks for all your advice
will try it in a couple of  days and report back to you
Message 7 of 16
BKSpurgeon
of course you'll catch "Exception" not myCustomException - i just cut and pasted without reading too closely. and unforutnately i cannot edit my original post.
BK
Message 8 of 16
hi BKSpurgeon
thx for the advice works great
see even debug messages from autocad coming threw
but was create another solution
was fix it by creating a pagesetup for every ;layout threw the database
and that works fine and then i make a publish of all to
and now i was try the catch exception and now it runs till the end
i gonna try today to break it again like i did before and then debug with the try exception
and will report back if i know more
but thx for the advice will use this in the future
Message 9 of 16
ihis is the error
 first chance exception of type 'System.AccessViolationException' occurred in Unknown Module.
not a lot of help to me
Message 10 of 16
@Anonymous wrote:
ihis is the error
No, indeed not of great help! Smiley Very Happy
But, cannot you debug it step by step and see where actually it throws the exception?
Anyway, a couple of ideas to follow: is your code still similar to what you posted at the beginning? As I suggested before, I'd load the documents as proper Document objects, without loading just the Database with ReadDWG().
And since you have to switch documents, I'd define the command with the 'CommandFlags.Session' attribute and then locking/unlocking the documents you load.
That way I know for sure it'd work, since it's the architecture I've been using for a while...
Message 11 of 16
hi mcicognani
will try that but i know it will work
even i not have tried it
here it is and by all means i am no specialist
and i was suppecting this from the beginning
and i think has something to do with closing and opening of the database
and it tries to allocate memory where it has no permission or something like that
and then i changed the exception in System.AccessViolationException to catch
that is what it said cant  write or no permision etc.
because i saw u could filter on exception in the debug menu of visual studio
changed the program omg tried to close the database like it should be
dispose of the plotsettings
dispose transaction
dispose of the layoutmanager
tried a lot
and now my unexperience comes in when i try  to debug the script
and i allready got the same result with adding to every layout a pagesetup and
making a publish of the files
but i just want to know why and how and what i did wrong
well get back with code for opening and closing the files and then plotting them
Message 12 of 16
like i promised
the code opening ans closing drawing and switching between the layouts and then printing
works fine
except i cant set my PlotPaperUnit not to milimeters stay on stupid inches grrrrrrrrrrrrrrrrrrrrrrrr
here is the code but i dont see what is gonna help me with the databases
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.AutoCAD.PlottingServices
Public Class dbtest
<CommandMethod("PUB", CommandFlags.Session)> _
Public Shared Sub Publish()
Try
Dim file As String
'Dim filenames() As String = openfdail.GetFilenames
Dim filenames() As String = openfdail.GetFilenames()
Dim acdocmgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
acDoc = DocumentCollectionExtension.Open(acdocmgr, file, False)
Dim db As Database = acDoc.Database
Dim aced As Editor = acDoc.Editor
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = acDoc
Using acLckDoc As DocumentLock = acDoc.LockDocument()
Dim ldic As DBDictionary = CType(actrans.GetObject(db.LayoutDictionaryId, OpenMode.ForRead), DBDictionary)
Dim lo As Layout = CType(actrans.GetObject(entr.Value, OpenMode.ForWrite), Layout)
Try
formaat = getform(acDoc, lo.LayoutName, db, aced)
plot(lo, db, filename, file, formaat, aced)
aced.WriteMessage(ex.ToString())
End Try
Next
actrans.Dispose()
End Using
End Using
DocumentExtension.CloseAndDiscard(acDoc)
Next
Debug.Print(ex.ToString())
End Try
End Sub
Case "HTCAF0a0"
Case "HTCAF1a0"
Case "HTCAF2a0"
Case "HTCAF0a1"
Case "HTCAF1a1"
Case "HTCAF0a2"
Case "HTCAF0a3"
Case "HTCAF0a4"
Case "HTCAF3a4"
Case "HTCAF4a4"
Case "HTCAF5a4"
Case "HTCAF6a4"
Case Else
End Select
Next
End Using
Else
formaat = "LEEG"
Return formaat
End Function
Public Shared Sub plot(ByRef lo As Layout, ByRef db As Database, ByVal filename As String, ByVal file As String, ByVal formaat As String, ByVal ed As Editor)
Dim CurVar As Object
'Get the BACKGROUNDPLOT SYSTEM VARIABLE
CurVar = Application.GetSystemVariable("BackGroundPlot")
'SET BACKGROUNDPLOT SYSTEM VARIABLE TO ZERO
Application.SetSystemVariable("BackGroundPlot", 0)
'' Get the PlotInfo from the layout
Dim acPlInfo As PlotInfo = New PlotInfo()
'' Set the PlotSettings object
'' Get a PlotSettings from the layout
Dim acPlSet As PlotSettings = New PlotSettings(lo.ModelType)
'' Set the plot scale
acPlSetVdr.SetPlotPaperUnits(acPlSet, PlotPaperUnit.Millimeters)
acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.StdScale1To1)
'acPlSet.ScaleLineweights = True
''set the style
'' Center the plot
''set the rotation
'acPlSetVdr.SetPlotRotation(acPlSet, Rotation) 'Rotations is passed through the function
'' Set the plot device to use
'' Set the plot info as an override
'' Validate the plot info
Dim acPlInfoVdr As PlotInfoValidator = New PlotInfoValidator()
acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, True)
lo.CopyFrom(acPlSet)
'' Check whether a plot job is in progress
If PlotFactory.ProcessPlotState = Autodesk.AutoCAD.PlottingServices.ProcessPlotState.NotPlotting Then
'' Track the plot progress with a Progress dialog
Dim acPlProgDlg As PlotProgressDialog = New PlotProgressDialog(False, 1, True)
Using (acPlProgDlg)
'' Define the status messages to display when plotting starts
acPlProgDlg.PlotMsgString(PlotMessageIndex.DialogTitle) = "Plot Progress"
acPlProgDlg.PlotMsgString(PlotMessageIndex.CancelJobButtonMessage) = "Cancel Job"
acPlProgDlg.PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage) = "Cancel Sheet"
acPlProgDlg.PlotMsgString(PlotMessageIndex.SheetSetProgressCaption) = "Sheet Set Progress"
acPlProgDlg.PlotMsgString(PlotMessageIndex.SheetProgressCaption) = "Sheet Progress"
'' Set the plot progress range
'' Display the Progress dialog
'' Start to plot the layout
file, _
Nothing, _
1, _
True, _
filename)
'' Set the sheet progress range
'' Plot the first sheet/layout
Dim acPlPageInfo As PlotPageInfo = New PlotPageInfo()
acPlEng.BeginPage(acPlPageInfo, _
acPlInfo, _
True, _
Nothing)
'' Finish plotting the sheet/layout
'' Finish plotting the document
'' Finish the plot
End Using
End Using
'REVERT BACK TO THE ORIGINAL BACKGROUNDPLOT SYSTEM VARIABLE
Application.SetSystemVariable("BackGroundPlot", CurVar)
End Sub
End Class
Message 13 of 16
Should be in the PlotSettingsValidator:
psv.SetPlotPaperUnits(ps, PlotPaperUnit.Millimeters);
EDIT:
No, sorry, seen you already did it...
What's the units of the drawings itself? Inches? If so, you just have to take into account and adjust the PlotScale factor...
EDIT2:
Look, someone else had the same issue:
http://forums.autodesk.com/t5/net/plotsettingsvalidator-setplotpaperunits/m-p/6025017/highlight/true...
Message 14 of 16
i know
i was put in my code and still keeps inches but will look online if i can find what i am doing wrong
but like i told u works when u open and close the drawing and switch the layouts and plot them
but for the database version still the same problem
Message 15 of 16
Hi Jorge.
Forgetting to commit a Transaction?
Message 16 of 16
hi mtb task
why should i commit if i do a override of the plotsettings
and i want to know what is wrong with plotpaperunits
but we are drifting away from the real problem
why i get a fata error when i try to the sme when i only open the database
i just want to plot and make no futther changes
