Create Named View from object in UCS
ediloreto8W6MG
ediloreto8W6MG
I'm trying to create named views from objects (for example a rectangle). Right now I'm using the object extends to get the view's centerpoint, widht and height using the following code.
public static ViewTableRecord CreateFromEntity(Entity entity)
            ViewTableRecord viewTableRecord = new ViewTableRecord();
            AssignEntityCoords(entity, ref viewTableRecord);
            return viewTableRecord;
private static void AssignEntityCoords(Entity entity, ref ViewTableRecord viewTableRecord)
            Extents3d ext = entity.GeometricExtents;
            Point2d centerPoint = new Point2d((ext.MinPoint.X + ext.MaxPoint.X) * 0.5, (ext.MinPoint.Y + ext.MaxPoint.Y) * 0.5);
            double width = Math.Abs(ext.MinPoint.X - ext.MaxPoint.X);
            double height = Math.Abs(ext.MinPoint.Y - ext.MaxPoint.Y);
            viewTableRecord.CenterPoint = centerPoint;
            viewTableRecord.Width = width;
            viewTableRecord.Height = height;
This is working great when using the WCS, but if I have a rotated rectangle the view is created like this:
I have tried applying trasformation to the entity before creating the view but didnt get any luck:
Matrix3d transf = Editor.CurrentUserCoordinateSystem; // Using a UCS
Entity newEntity = entity.GetTransformedCopy(transf);
ViewTableRecord view = CreateFromEntity(newEntity);
In short, I am trying to make a view that aligns with UCS. This can be done easily from the view manager but it becomes tedious to make many views.
ediloreto8W6MG
Anyone has an idea on how to do it? I couldn't solve it yet...
