Create image from Geometry
BrentBurgess1980
BrentBurgess1980
Hi All,
I am trying to create an image of of a polyline to be used in an image, however, I have not been able to find anything that would help.
I have tried creating a block but this hasn't been as successful as I'd hoped.
If it were just straight line segments, I could probably conjure something up with points and draw an image, but as there may be curves in the polyline, I am not sure how I would tackle that.
I have googled
Image from Entity
Copy Entity to Clipboard (thinking I could use the image)
Generate Bitmap from Entity
and other variations of the above.
Does anyone have any tips or references for this?
Brent
SENL1362
And the problem is?
Have a look at CapturePreviewImage
Sample:
//Turn layers on/off and or set LineWeight
db.UpdateExt(true);
dynamic acadApp = AcadApp.AcadApplication;
acadApp.ZoomExtents();
ed.ZoomScale(1.03);
var size = doc.Window.DeviceIndependentSize;
using (var bmp = doc.CapturePreviewImage(Convert.ToUInt32(size.Width), Convert.ToUInt32(size.Height)))
//TopLeft Pixel must be backgroud to make it transparent, use ZoomScale(1.03)
var firstPxl = bmp.GetPixel(0, 0);  //255,0,0  white or Black
bmp.MakeTransparent(firstPxl);
if (File.Exists(IconPathname))
File.Delete(IconPathname);
bmp.Save(IconPathname, System.Drawing.Imaging.ImageFormat.Png);
R.Gerritsen4967
Instead of using the PreviewImage of a drawing you can also make a plot to a file.
See this example for plotting to a PDF file. If you change the plotconfiguration file to the 'PublishToWeb PNG.pc3', it is possible to plot to a .png file.
hippe013
Did you happen to read Kean's updated post regarding the original link that you posted about generating an image from blocks?
https://through-the-interface.typepad.com/through_the_interface/2013/11/generating-larger-preview-im...
BlackBox_
Love that lil' trick:
https://forums.augi.com/showthread.php?172533-PNGOUT-with-transparent-background-option&p=1338401&vi...
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
