Create Hatch in Outer Block and exclude inner block
saikiran.nT432F
saikiran.nT432F
Hi All,
I have a requirement where i want to craete hatch only for the outer block and need exclude the inner block. I have tried the following steps but none worked so far.
1.  Hatchstyle enum as shown in example of below link
https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-01A47A4F-9FC5-4DB6-8C3E-B72D75688965
hatch.HatchStyle = HatchStyle.Outer;
                  (or)
hatch.HatchStyle = HatchStyle.Normal;
2. Create Hatch for Outer block and remove hatch in inner block (instead of blocks also tried for polyline)
3. Tried to achieve with below code
Hatch hatch = new Hatch();
hatch.SetDatabaseDefaults();
hatch.SetHatchPattern(HatchPatternType.PreDefined, "ANGLE");
hatch.PatternScale = 1;
hatch.AppendLoop(HatchLoopTypes.Outermost, new ObjectIdCollection { polyline.ObjectId });
ObjectId hatchId = modelSpace.AppendEntity(hatch);
tr.AddNewlyCreatedDBObject(hatch, true);
Your ideas and response on this matter is highly appreciated. Thanks in advance.
ActivistInvestor
@saikiran.nT432F wrote:
Hi All,
                  (or)
You need to read the documentation better, and look at the example it includes, because it clearly outlines what steps you must take. What the docs don't explicitly mention is that you must add the hatch to the database and transaction first, before you take any further steps.
The code you show above does not call AppendLoop() to add the inner loop(s) to the hatch (after adding the outer loop), and also does not call EvaluateHatch()
