Create database resident system variable
Is it possible to create a database resident system variable? My desire is to create a system variable that I can use to expose results of my program, and/or let the user set values that the program can use. I thought I saw an example somewhere, but I can't seem to find it now.
Any Ideas?
HomeBoy Out
No way to create your own system variables.
You can store data in dictionaries and provide your own UI or command to let
the user view or change them.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6166438@discussion.autodesk.com...
example somewhere, but I can't seem to find it now. Any Ideas? Thanks
HomeBoy Out
See AutoCAD help for info on USERI1-5 & USERR1-5 system variables. Obvious shortcomings are limited number of variables and knowing they aren't/won't be used by another person/program.
Or.... P/Invoke:
 acedGetEnv and acedSetEnv
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<HomeBoyLV>
now. Any Ideas? Thanks HomeBoy Out
I think you're confusing storing data in a DWG file with
storing it in the registry.
wrote in message news:6166949@discussion.autodesk.com...
Or.... P/Invoke:
HomeBoy Out
Thanks Tony and yes,
Please ignore what I just previously posted 🙂
"Tony Tanzillo"
Very old post, but from AutoCAD 2011 onwards it is possible to create a custom system variable by adding a key to the registry.
Your user might need elevated UAC permissions to be able to add it to the registry's local-machine hive, but this can be achieved by your installer.
There's more information contained at the bottom of the following through-the-interface post for those who are interested Custom System Variable Link
Art
