Create Block with Hatch
vkpunique
vkpunique
Hi, I am Trying to create Block with hatch inside them. I can Create Block with Polyline or any other entity but no Sucess with Hatch. Can Anyone Provide Right Reference for this problem?
Why No documentation available for this? It Very common use case for any drawing.
vkpunique
Hi, @_gile . I mean Insert new Block Defination with Hatch. Sorry For Bad title
_gile
What's your problem? Creating a block definition which contains a Hatch ou inserting such block ?
Please elaborate and/or provide some code.
Gilles Chanteau
GileCAD
GitHub
vkpunique
Hi @_gile ,
I am Trying to Create Block Definition with Hatch. I am working on it for last few hours. Finally I've found below code which is working but I have to create whole drawing first before creating block from it. Is there any better way to do this?
Check out Sample Code in Attached File.  I am looking for Any Improvement or Alternative to that code ?
_gile
You add a Hatch in a block definition (BlockTableRecord) exactly the same way as you do it in the model space (BlockTableRecord)
From this reply:
private static ObjectId CreateBlockWithHatch(Database db, string blockName)
            using (var tr = db.TransactionManager.StartTransaction())
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord block;
                if (bt.Has(blockName)) return bt[blockName];
                tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                block = new BlockTableRecord();
                block.Name = blockName;
                var blockId = bt.Add(block);
                tr.AddNewlyCreatedDBObject(block, true);
                var pline = new Polyline(4) { Closed = true, Layer = "0" };
                pline.Layer = "0";
                pline.AddVertexAt(0, new Point2d(-12.0, -12.0), 0.0, 0.0, 0.0);
                pline.AddVertexAt(0, new Point2d(12.0, -12.0), 0.0, 0.0, 0.0);
                pline.AddVertexAt(0, new Point2d(12.0, 12.0), 0.0, 0.0, 0.0);
                pline.AddVertexAt(0, new Point2d(-12.0, 12.0), 0.0, 0.0, 0.0);
                block.AppendEntity(pline);
                tr.AddNewlyCreatedDBObject(pline, true);
                var circle = new Circle() { Center = Point3d.Origin, Radius = 8.0, Layer = "0" };
                block.AppendEntity(circle);
                tr.AddNewlyCreatedDBObject(circle, true);
                var ids = new ObjectIdCollection(new[] { circle.ObjectId });
                var hatch = new Hatch() { Layer = "0", PatternScale = 0.5, ColorIndex = 1 };
                hatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31");
                block.AppendEntity(hatch);
                tr.AddNewlyCreatedDBObject(hatch, true);
                hatch.Associative = true;
                hatch.AppendLoop(HatchLoopTypes.Default, ids);
                hatch.EvaluateHatch(true);
                tr.Commit();
                return blockId;
Gilles Chanteau
GileCAD
GitHub
