create a parametric dimension and set its "Reference" parameter to true
How do you create a parametric dimension and make it a reference dimension?
deepak.a.s.nadig
AssocDimDependencyBodyBase.IsReferenceOnly needs to be set True for this. Below is an
example which creates aligned dimensional constraint and sets its Reference property to true.
    Public Class MyCommands
        'Add an aligned dimensional constraint to a Line.
        <CommandMethod("TESTALIGNEDDIM")>
        Public Shared Sub testAlignedDimCommand()
            Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
            Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
            Using myT As Transaction = tm.StartTransaction()
                ' Point entities
                Dim bt As BlockTable = DirectCast(myT.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
                Dim btr As BlockTableRecord = DirectCast(myT.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, False), BlockTableRecord)
                Dim point3d1 As New Point3d(10, 10, 0)
                Dim point3d2 As New Point3d(20, 20, 0)
                Dim dimPt As New Point3d(36, 20, 0)
                Dim line1 As New Line(point3d1, point3d2)
                btr.AppendEntity(line1)
                myT.AddNewlyCreatedDBObject(line1, True)
                ' Aligned Dimension entity
                Dim dimAligned As New AlignedDimension(point3d1, point3d2, dimPt, "ALIGNED DIMENSION", db.Dimstyle)
                btr.AppendEntity(dimAligned)
                myT.AddNewlyCreatedDBObject(dimAligned, True)
                Dim idConstrGroup As ObjectId = ObjectId.Null
                'To query the subentities of the line, we create and use a protocol extension (PE) provided by the associativity API
                Dim subentityIdPE As AssocPersSubentityIdPE
                Dim peCls As RXClass = AssocPersSubentityIdPE.GetClass(GetType(AssocPersSubentityIdPE))
                Dim pSubentityIdPE As IntPtr = line1.QueryX(peCls)
                If pSubentityIdPE = IntPtr.Zero Then
                    System.Windows.MessageBox.Show("cannot get pSubentityIdPE")
                    Return
                subentityIdPE = TryCast(AssocPersSubentityIdPE.Create(pSubentityIdPE, False), AssocPersSubentityIdPE)
                If subentityIdPE Is Nothing Then
                    System.Windows.MessageBox.Show("cannot get subentityIdPE")
                    Return
                'Now we have the PE, we query the subentities
                Dim edgeSubentityIds As SubentityId() = Nothing
                'First we retrieve a list of all edges (a line has one edge)
                edgeSubentityIds = subentityIdPE.GetAllSubentities(line1, SubentityType.Edge)
                Dim startSID As SubentityId = SubentityId.Null, endSID As SubentityId = SubentityId.Null
                Dim other As SubentityId() = Nothing
                'Now we retrieve the vertices associated with that edge.
                subentityIdPE.GetEdgeVertexSubentities(line1, edgeSubentityIds(0), startSID, endSID, other)
                'The PE returns a SubEntId. We want a Full SubentityPath
                Dim subentPathEdge As New FullSubentityPath(New ObjectId(0) {line1.ObjectId}, edgeSubentityIds(0))
                Dim subentPath1 As New FullSubentityPath(New ObjectId(0) {line1.ObjectId}, startSID)
                Dim subentPath2 As New FullSubentityPath(New ObjectId(0) {line1.ObjectId}, endSID)
                'add dimconstraint to the entities
                'create value dependency
                Dim varId As ObjectId, valDepId As ObjectId
                varId = AddOrModifyVariable("Aligned", "10.0")
                Using valDep As New AssocValueDependency()
                    valDepId = db.AddDBObject(valDep)
                    Dim compoundId As New CompoundObjectId(varId, db)
                    valDep.AttachToObject(compoundId)
                End Using
                'create dim dependency
                Dim dimDepId As ObjectId = ObjectId.Null
                Dim dimDepBodyId As ObjectId = ObjectId.Null
                AssocDimDependencyBody.CreateAndPostToDatabase(dimAligned.ObjectId, dimDepId, dimDepBodyId)
                Dim bPreviousValue As Boolean = AssocDimDependencyBodyBase.SetEraseDimensionIfDependencyIsErased(False)
                Dim consGrpId As ObjectId = GetConstraintGroup(True)
                Dim consGeom0 As ConstrainedGeometry = Nothing
                Dim consLine As ConstrainedLine = Nothing
                Using constGrp As Assoc2dConstraintGroup = DirectCast(myT.GetObject(consGrpId, OpenMode.ForWrite, False), Assoc2dConstraintGroup)
                    consGeom0 = constGrp.AddConstrainedGeometry(subentPathEdge)
                    'Sometimes you have to access implicit constrained geometry.
                    'In this case, we're constraining the lines by its endpoints, so we have to query the constrained line edge for its ConstrainedImplicitPoints.
                    'If we try to pass the line's end point subentity directly via a call to AddConstrainedGeometry, we'll get an error.
                    consLine = DirectCast(consGeom0, ConstrainedLine)
                    Dim consPts As ConstrainedImplicitPoint() = consLine.ConstrainedImplicitPoints
                    Dim consStartPt As ConstrainedGeometry = Nothing
                    Dim consEndPt As ConstrainedGeometry = Nothing
                    'We don't know which is start or end point, so we test. (And we could have a midpoint in there too).
                    For Each pt As ConstrainedImplicitPoint In consPts
                        If pt.PointType = ImplicitPointType.StartImplicit Then
                            consStartPt = pt
                        If pt.PointType = ImplicitPointType.EndImplicit Then
                            consEndPt = pt
                    Next
                    'If something went wrong ...
                    If (consStartPt Is Nothing) OrElse (consEndPt Is Nothing) Then
                        Return
                    'Now we add our constraint
                    constGrp.AddDistanceConstraint(consStartPt, consEndPt, DistanceConstraint.DistanceDirectionType.NotDirected, valDepId, dimDepId, New Vector3d(1, 0, 0),
           Nothing)
                    AssocDimDependencyBodyBase.SetEraseDimensionIfDependencyIsErased(bPreviousValue)
                    Using assocDimBody As AssocDimDependencyBody = myT.GetObject(dimDepBodyId, OpenMode.ForWrite, False)
                        assocDimBody.IsReferenceOnly = True
                    End Using
                End Using
                myT.Commit()
            End Using
        End Sub
        ' Helper function to return FullSubEntPath for subent of provided entity
        Private Shared Function GetFullSubentityPath(ByVal entity As Entity, ByVal subentityType As SubentityType) As FullSubentityPath
            If entity Is Nothing Then
                System.Windows.MessageBox.Show("cannot get entity")
                Return New FullSubentityPath()
            Dim pSubentityIdPE As IntPtr = entity.QueryX(peCls)
            edgeSubentityIds = subentityIdPE.GetAllSubentities(entity, subentityType)
            Return New FullSubentityPath(New ObjectId(0) {entity.ObjectId}, edgeSubentityIds(0))
        End Function
        ' Helper function to retrieve (or create) constraint group
        Private Shared Function GetConstraintGroup(ByVal createIfDoesNotExist As Boolean) As ObjectId
            ' Calculate the current plane on which new entities are added by the editor
            ' (A combination of UCS and ELEVATION sysvar).
            Dim ed As Autodesk.AutoCAD.EditorInput.Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            Dim ucsMatrix As Matrix3d = ed.CurrentUserCoordinateSystem
            Dim origin As Point3d = ucsMatrix.CoordinateSystem3d.Origin
            Dim xAxis As Vector3d = ucsMatrix.CoordinateSystem3d.Xaxis
            Dim yAxis As Vector3d = ucsMatrix.CoordinateSystem3d.Yaxis
            Dim zAxis As Vector3d = ucsMatrix.CoordinateSystem3d.Zaxis
            origin = origin + CDbl(Application.GetSystemVariable("ELEVATION")) * zAxis
            Dim currentPlane As New Plane(origin, xAxis, yAxis)
            ' get the constraint group from block table record
            Dim networkId As ObjectId = AssocNetwork.GetInstanceFromObject(SymbolUtilityServices.GetBlockModelSpaceId(db), createIfDoesNotExist, True, "")
            If networkId.IsNull Then
                System.Windows.MessageBox.Show("network id is null")
                Return idConstrGroup
            ' Try to find the constraint group in the associative network
                Using network As AssocNetwork = DirectCast(myT.GetObject(networkId, OpenMode.ForRead, False), AssocNetwork)
                    If network Is Nothing Then
                    ' Iterate all actions in network to find Assoc2dConstraintGroups
                    Dim actionsInNetwork As ObjectIdCollection = network.GetActions
                    For nCount As Integer = 0 To actionsInNetwork.Count - 1
                        Dim idAction As ObjectId = actionsInNetwork(nCount)
                        If idAction = ObjectId.Null Then
                            Continue For
                        ' Is this action a type of Assoc2dConstraintGroup?
                        If idAction.ObjectClass.IsDerivedFrom(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.Assoc2dConstraintGroup))) Then
                            Using action As AssocAction = DirectCast(myT.GetObject(idAction, OpenMode.ForRead, False), AssocAction)
                                If action Is Nothing Then
                                    Continue For
                                Dim constGrp As Assoc2dConstraintGroup = DirectCast(action, Assoc2dConstraintGroup)
                                ' Is this the Assoc2dConstraintGroup for our plane of interest?
                                If constGrp.WorkPlane.IsCoplanarTo(currentPlane) Then
                                    ' If it is then we've found an existing constraint group we can use.
                                    Return idAction
                            End Using
                    Next
                End Using
                ' If we get to here, a suitable contraint group doesn't exist, create a new one if that's what calling fn wanted.
                If idConstrGroup.IsNull AndAlso createIfDoesNotExist Then
                    Using network As AssocNetwork = DirectCast(myT.GetObject(networkId, OpenMode.ForWrite, False), AssocNetwork)
                        ' Create  construction plane
                        Dim constraintPlane As New Plane(currentPlane)
                        ' If model extent is far far away from origin then we need to shift
                        '  construction plane origin within the model extent.
                        ' (Use Pextmin, PExtmax in paper space)
                        Dim extmin As Point3d = db.Extmin
                        Dim extmax As Point3d = db.Extmax
                        If extmin.GetAsVector().Length > 100000000.0 Then
                            Dim originL As Point3d = extmin + (extmax - extmin) / 2.0
                            Dim result As PointOnSurface = currentPlane.GetClosestPointTo(originL)
                            constraintPlane.[Set](result.GetPoint(), currentPlane.Normal)
                        ' Create the new constraint group and add it to the associative network.
                        Using constGrp As New Assoc2dConstraintGroup(constraintPlane)
                            idConstrGroup = db.AddDBObject(constGrp)
                        End Using
                        network.AddAction(idConstrGroup, True)
                    End Using
                myT.Commit()
            End Using
        End Function
        ' Helper function to add a new variable to the associative network or modify expression of the existing one
        Private Shared Function AddOrModifyVariable(ByVal varName As String, ByVal varExpression As String) As ObjectId
            Dim varId As ObjectId = ObjectId.Null
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Using myT As Transaction = db.TransactionManager.StartTransaction()
                ' Open the AssocNetwork
                Dim networkId As ObjectId = AssocNetwork.GetInstanceFromObject(SymbolUtilityServices.GetBlockModelSpaceId(db), True, True, "")
                Dim network As AssocNetwork = DirectCast(myT.GetObject(networkId, OpenMode.ForWrite), AssocNetwork)
                Dim var As AssocVariable = Nothing
                ' Iterate through all actions in the network
                Dim actionIds As ObjectIdCollection = network.GetActions
                For Each actionId As ObjectId In network.GetActions
                    ' Is this action an AssocVariable?
                    If actionId.ObjectClass.IsDerivedFrom(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.AssocVariable))) Then
                        ' If so, we check if it has the name we're looking for.
                        var = DirectCast(myT.GetObject(actionId, OpenMode.ForWrite), AssocVariable)
                        If var IsNot Nothing Then
                            ' If name matches, then we exit loop and set its expression
                            If var.Name = varName Then
                                Exit For
                            Else
                                var = Nothing
                Next
                ' If variable with correct name wasn't found, we create it.
                If var Is Nothing Then
                    var = New AssocVariable()
                    varId = network.Database.AddDBObject(var)
                    network.AddAction(varId, True)
                    myT.AddNewlyCreatedDBObject(var, True)
                    var.SetName(varName, True)
                ' Finally we set its expression to the new value.
                Dim errMsg As String = ""
                var.SetExpression(varExpression, "", True, True, errMsg, False)
                Dim rb As New ResultBuffer()
                errMsg = var.EvaluateExpression(rb)
                var.Value = rb
                myT.Commit()
            End Using
            Return varId
        End Function
        ' Helper function to handle exceptions being thrown if you try to add the same constrained geometry twice.
        ' You could work out what constrained geometry to add up front. That would be more efficient as no exceptions would be thrown,
        '  but isn't always possible (e.g. if running a command multiple times to constrain existing geometry in a drawing.
        ' (This helper function isn't used by any functions in this sample project).
        Private Shared Function AddConstrainedGeometry(ByVal constGrp As Assoc2dConstraintGroup, ByVal path As FullSubentityPath) As ConstrainedGeometry
            Dim consGeom As ConstrainedGeometry = Nothing
            Try
                consGeom = constGrp.AddConstrainedGeometry(path)
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                ' This error isn't really an an error
                If ex.ErrorStatus <> ErrorStatus.AlreadyInGroup Then
                    Throw ex
                ' If we get to here, then 'path' was already in the group so we can retrieve it.
                consGeom = constGrp.GetConstrainedGeometry(path, False)
            End Try
            Return consGeom
        End Function
    End Class
I do not see AssocDimDependencyBodyBase.IsReferenceOnly in the code you sent
deepak.a.s.nadig
AssocDimDependencyBody inherits from AssocDimDependencyBodyBase class . IsReferenceOnly
is a member of AssocDimDependencyBodyBase. Please look for the following lines in the code that I have posted earlier :
End Using
This does not create a parametric dimension. It creates a normal dimension. I need a parametric dimension that is a reference dimension
