I tried your suggestions at home and the build still failed with the following message:
Could not load file or assembly 'accoremgd, Version=23.0.0.0, Culture=neutral, PublicKeyToken=null'
or one of its dependencies. The system cannot find the file specified.
Here is a summary of the steps I have taken and the results:
1. start Visual Studio 2017 as administrator
2. start a new Visual Basic class library project
3. set project properties
4. set target framework = .Net Framework 4.7.1
5. Make assembly COM-Visible = check
6. set Target CPU = x64
7. Register for COM interop = check
8. Start action = Start project
9. References (all in C:\Program Files\Autodesk\AutoCAD 2019)
accoremgd.dll
acdbmgd.dll
acmgd.dll
AcWindows.dll
Autodesk.AutoCAD.Interop.dll
Autodesk.AutoCAD.Interop.Common.dll
10. added code (see code below )
11. in VS select build - build
12. get error noted above
13. the following files were created in "C:\custom\ccTools\ccTools\bin\x64\Debug"
acmgd.dll
ccTools.dll
ccTools.pdb
ccTools.xml
14. nothing was added to the registry
15. ccTools runs successfully in AutoCAD using NetLoad as the command line
code --------------------------------------------
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Public Class SolidsCLS
<CommandMethod("Test123")>
Public Sub ExtrudeRegionTest()
Dim pStartPoint As Point3d
Dim pEndPoint As Point3d
Dim pDiameter As Double
pStartPoint = New Point3d(100, 200, 300)
pEndPoint = New Point3d(200, 300, 400)
pDiameter = 10
CylinderExtrude(pStartPoint, pEndPoint, pDiameter)
End Sub
Public Function CylinderExtrude(
ByVal iStartpoint As Point3d,
ByVal iEndPoint As Point3d,
ByVal iDiameter As Double
) As Solid3d
Dim pDirectionVector = New Vector3d(
iEndPoint.X - iStartpoint.X,
iEndPoint.Y - iStartpoint.Y,
iEndPoint.Z - iStartpoint.Z
Dim pCircle As New Circle(iStartpoint, pDirectionVector, iDiameter / 2)
Dim pDBObjColl As DBObjectCollection = New DBObjectCollection()
pDBObjColl.Add(pCircle)
Dim pRegionColl As DBObjectCollection = New DBObjectCollection()
pRegionColl = Autodesk.AutoCAD.DatabaseServices.Region.
CreateFromCurves(pDBObjColl)
Dim pRegion As Region = pRegionColl(0)
Dim myTransMan As Autodesk.AutoCAD.ApplicationServices.TransactionManager
Dim myTrans As Transaction
Dim myDWG As Document
Dim myBT As BlockTable
Dim myBTR As BlockTableRecord
myDWG = Autodesk.AutoCAD.ApplicationServices.Application.
DocumentManager.MdiActiveDocument
Dim myLock As DocumentLock
myLock = myDWG.LockDocument
myTransMan = myDWG.TransactionManager
myTrans = myTransMan.StartTransaction
myBT = myDWG.Database.BlockTableId.GetObject(OpenMode.ForRead)
myBTR = myBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite)
Dim pSolid As Solid3d
pSolid = New Autodesk.AutoCAD.DatabaseServices.Solid3d
pSolid.RecordHistory = True
Dim DirectionVector = New Vector3d(
Dim mySweepOptions As New SweepOptions()
pSolid.CreateExtrudedSolid(pRegion, DirectionVector, mySweepOptions)
myBTR.AppendEntity(pSolid)
myTrans.AddNewlyCreatedDBObject(pSolid, True)
myTrans.Commit()
myTrans.Dispose()
myTransMan.Dispose()
Return pSolid
myLock.Dispose()
DocumentManager.MdiActiveDocument.Editor.Regen()
End Function
End Class
Thanks for your help so far and if you could take a look a look at this again I would very much appreciate it.
Fred
