Crashing AutoCAD 2009 any time I prompt for user input
AdammReilly
AdammReilly
I'm running Civil 3D 2009, and Visual Basic 2008 Express.
I was going to work on a small project, but I've run several test programs to prompt for different user input methods. Every time I prompt for user input at all, Autocad crashes.
I need some help. Everything looks correct, and I'm getting pretty irritated at this.
This is the code I have:
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Imports DbTransMan = Autodesk.AutoCAD.DatabaseServices.TransactionManager
Imports Autodesk.AutoCAD.EditorInput
Public Class HCE_Tools
    <CommandMethod("TestString")> _
    Sub WriteStringToUser()
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        ed.WriteMessage("Hello World!")
    End Sub
    <CommandMethod("TestPoint")> _
Sub PromptUserForPoint()
        Dim prPtOpts As New PromptPointOptions(vbLf + "Pick a point:")
        prPtOpts.AllowNone = True 'Allow ENTER only
        prPtOpts.AppendKeywordsToMessage = False
        Dim prPtResult As PromptPointResult
        prPtResult = ed.GetPoint(prPtOpts)            <---- This is where it always crashes at
        ed.WriteMessage(prPtResult.ToString)
    End Sub
End Class
Adam Reilly
Civil 3D 2026
Creator A16 AI+ A3HVFG
Windows 11 Pro
AMD Ryzen AI 9 365 w/ Radeon 880M
LinkedIn
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
fieldguy
The 1st argument for New PromptPointOptions is messageandkeywords as string.  My guess is it doesn't like your input.  Try it this way:
Dim prPtOpts As PromptPointOptions = New PromptPointOptions("")
prPtOpts.Message = vbLf & "Pick a point:"
AdammReilly
That didn't do it. Still got the same error.
Can't seem to catch the error either.
Adam Reilly
Civil 3D 2026
Windows 11 Pro
LinkedIn
Group Leader badge
LinkedIn | Discord
chiefbraincloud
I don't think this is going to be helpful at soothing your irritation, but I pasted your TestPoint Function into my code and ran it, it worked fine.  There were two things I was going to look at, one being that in VB, I prefer to use the & instead of + to concatenate strings, the other was setting AppendKeywordsToMessage to false without any keywords, but it doesn't seem to have a problem with either.
My Text Window output:
Command: testpoint
Pick a point: ((OK,),(5.84749117416629,4.5328068004761,0))
Command:  TESTPOINT
Pick a point: ((OK,),(4.30410913085712,3.24291119397888,0))
Command:  TESTPOINT
Pick a point: *Cancel*
((Cancel,),(0,0,0))
Command:  TESTPOINT
Pick a point:
((None,),(0,0,0))
Command:
TESTPOINT
Pick a point: fred
Invalid point.
Pick a point: f
Invalid point.
((Cancel,),(0,0,0))
I was running this in AutoCAD 2010, but I used 2009 for two years, and I didn't have any wierd problems getting user input.
fieldguy
Your code works as is for me - in acad 2011.  I do not have 2009 installed anymore.
Good luck!
