Convert Body to Solid3d
essam-salah
Advisor Advisor
essam-salah
Can we convert Autodesk.Autocad.DatabaseServices.Body to Autodesk.Autocad.DatabaseServices.Solid3d. ?
Any help will be appreciated.
Thanks in advance.
khodulieucuong
try { Solid3d solid = new Solid3d();
Entity[] boundaryEntities = new Entity[] { body };
solid.CreateSculptedSolid(boundaryEntities, new IntegerCollection());
essam-salah
not working too.
Autodesk.AutoCAD.Runtime.Exception: eGeneralModelingFailure
at Autodesk.AutoCAD.Runtime.Interop.ThrowExceptionForErrorStatus(Int32 errorStatus)
at Autodesk.AutoCAD.DatabaseServices.Solid3d.CreateSculptedSolid(Entity[] limitingBodies, IntegerCollection limitingFlags)
essam-salah
hi @_gile
any idea !!
essam-salah
unfortunalty couldn't solve it yet
khodulieucuong
using Autodesk.AutoCAD.BoundaryRepresentation;
using (Brep brep = new Brep(manualBody))
    // If the Brep structure doesn't represent a valid solid volume,
    // Solid3d conversion will fail.
    if (brep.GetComplex() == null)
        // It's likely a Surface or a non-solid Body
