convert Arc to polyline
youssefGC
youssefGC
Hi everyone,
There is a way to convert arc segment to polyline object ?
MGO-Norsyn
Yes, create new Polyline, add the two arc ends as vertices, calculate bulge and set it for the polyline segment.
MGO-Norsyn
double r = arc.Radius;
double u = arcStartPoint.GetDistanceTo(arcEndPoint);
double b = (2 * (r - Math.Sqrt(r.Pow(2) - u.Pow(2) / 4))) / u;
_gile
Here's an example (refactored code):
                var pline = new Polyline();
                double angle = arc.EndAngle - arc.StartAngle;
                if (angle < 0.0)
                    angle += 2.0 * Math.PI;
                double bulge = Math.Tan(angle / 4.0);
                var plane = new Plane(Point3d.Origin, arc.Normal);
                pline.AddVertexAt(0, arc.StartPoint.Convert2d(plane), bulge, 0.0, 0.0);
                pline.AddVertexAt(1, arc.EndPoint.Convert2d(plane), 0.0, 0.0, 0.0);
                pline.Normal = arc.Normal;
Gilles Chanteau
GileCAD
GitHub
youssefGC
Thank you _gile, I'm still learning from your tricks.
youssefGC
Thank you, but it doesn't march when I put an arc with an angle greater than 180 degrees
