convert angle from ucs to wcs
I have derived an angle from an entity in UCS. Can someone tell me how to convert this angle to the correct angle in WCS?
Frank
Alfred.NESWADBA
project these entities to WCS and get then the angle 😉
You don't need to add these projected entities to the database, you can .dispose them on end of your calculation.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Hi Alfred,
The function I am working on works like this: the user picks a random point on an entity. The angle is derived from the entity at the picked point. So I only have the angle as result. But when the user works in a UCS I have to translate the angle to WCS to be able to work with it.
I would prefere to calculate the new angle.
Frank
Alfred.NESWADBA
how do you request the angle now? Just one point is not enough for me, an angle could be calculated between to straight elements. Could you show this code-snippet?
- alfred -
Alfred NESWADBA
Hi Alfred,
Here is the code I use
       Public Shared Function GetAngleAtPointOnLine() As AngleAtPointOnLineClass
            Dim retValue As New AngleAtPointOnLineClass
            Try
                Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
                Dim myEd As Editor = acDoc.Editor
                Dim bObject As New PromptNestedEntityOptions("")
                Dim opt As PromptPointOptions = New PromptPointOptions("Select point on object: ")
                bObject.NonInteractivePickPoint = myEd.GetPoint(opt).Value
                bObject.UseNonInteractivePickPoint = True
                Dim bRes As PromptNestedEntityResult = myEd.GetNestedEntity(bObject)
                If bRes.Status = PromptStatus.OK Then
                    Using myTrans As Transaction = acDoc.TransactionManager.StartTransaction
                        'the return value of your nested selection may not always be one of
                        'those things that derives from curve, so you should check it first!
                        If bRes.ObjectId.ObjectClass.IsDerivedFrom(Curve.GetClass(GetType(Curve))) Then
                            Dim crv As Curve = myTrans.GetObject(bRes.ObjectId, OpenMode.ForRead, False, True)
                            Dim wcsPoint As Point3d = bRes.PickedPoint.TransformBy(myEd.CurrentUserCoordinateSystem)
                            Dim myFirstDerivative As Vector3d = crv.GetFirstDerivative(wcsPoint)
                            retValue.Angle = Math.Atan2(CDbl(myFirstDerivative.Y), CDbl(myFirstDerivative.X)) * (180 / Math.PI)
                            retValue.point = New Point3d(bRes.PickedPoint.X, bRes.PickedPoint.Y, bRes.PickedPoint.Z)
                    End Using
                retValue.HasError = False
            Catch ex As Exception
                retValue.HasError = True
                Debug.Print(ex.Message)
            End Try
            Return retValue
        End Function
    End Class
    Public Class AngleAtPointOnLineClass
        Public HasError As Boolean
        Public Angle As Double
        Public point As Point3d
    End Class
I found parts of the code on internet. I more or less understand what is happening. As you can see the angle is derived from the exact location on the object. In WCS this function works fine. In UCS the point comes out correctly, but the angle not. The angle needs to be corrected to an angle in WCS.
Frank
Balaji_Ram
Hi Frank,
The derivative vector is always in WCS. To convert it to UCS can you try this ?
<code>
Dim myFirstDerivative AsVector3d = crv.GetFirstDerivative(wcsPoint)
 Dim wcs2ucs AsMatrix3d
wcs2ucs = myEd.CurrentUserCoordinateSystem.Inverse()
myFirstDerivative = myFirstDerivative.TransformBy(wcs2ucs)
</code>
Balaji
Developer Technical Services
Autodesk Developer Network
Thanks very much Balaji.
The CurrentUserCoordinateSystem.Inverse function returns the desired vector for calculating the correct angle.
Frank
