Continue another command without closing the current window view
traiduong014969
Message 1 of 12
traiduong014969
Hi all,
I've just created an interface window in AutoCAD using C# in WPF with the MVVM format. However, I've encountered some issues.
For details:
In the window view, I've created two buttons (SnapOnCommand and SnapOffCommand), which are functioning correctly. However, I would like to implement several other commands in AutoCAD without closing the window application.
Could anyone provide assistance with this matter?
// code in view
<Button Grid.Column="0"
        Grid.Row="6"
        Content="snap on"
        Command="{Binding SnapOnCommand}"
        CommandParameter="{Binding ElementName=MainWindow}" />
        Grid.Row="7"
        Content="snap off"
        Command="{Binding SnapOffCommand}"
// code in model
public class HCNModel : BaseViewModel
    public void DuplicateAndExplode(out List<ObjectId> explodedObjectIds)
        Document doc = Application.DocumentManager.MdiActiveDocument;
        Database db = doc.Database;
        Editor ed = doc.Editor;
        explodedObjectIds = new List<ObjectId>();
        PromptEntityResult per = ed.GetEntity("\nchoose entity: ");
        if (per.Status != PromptStatus.OK)
            return;
        using (Transaction tr = db.TransactionManager.StartTransaction())
            BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
            BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
            Entity ent = tr.GetObject(per.ObjectId, OpenMode.ForRead) as Entity;
            if (ent == null)
                return;
            Entity entCopy = ent.Clone() as Entity;
            if (entCopy == null)
                return;
            DBObjectCollection explodedObjects = new DBObjectCollection();
            entCopy.Explode(explodedObjects);
            foreach (DBObject obj in explodedObjects)
                Entity explodedEntity = obj as Entity;
                if (explodedEntity != null)
                    ObjectId explodedObjectId = btr.AppendEntity(explodedEntity);
                    tr.AddNewlyCreatedDBObject(explodedEntity, true);
                    explodedObjectIds.Add(explodedObjectId);
            tr.Commit();
    public void DeleteExplodedObjects(List<ObjectId> explodedObjectIds)
        if (explodedObjectIds == null || explodedObjectIds.Count == 0)
            return;
        if (doc == null)
            return;
        using (var tr = doc.TransactionManager.StartTransaction())
            foreach (var objectId in explodedObjectIds)
                try
                    Entity ent = tr.GetObject(objectId, OpenMode.ForWrite) as Entity;
                    if (ent != null && !ent.IsErased)
                        if (ent.OwnerId != ObjectId.Null)
                            ent.Erase();
                catch (System.Exception ex)
                    doc.Editor.WriteMessage($"\nerror: {ex.Message}");
            tr.Commit();
// code in viewmode
public class HCNViewModel : BaseViewModel
 private List<ObjectId> _duplicatedObjectIds = new List<ObjectId>();
 private HCNModel _HCNModel;
public HCNModel HCNModel
    get { return _HCNModel; }
    set { _HCNModel = value; OnPropertyChanged(nameof(HCNModel)); }
 public ICommand SnapOnCommand { get; set; }
 public ICommand SnapOffCommand { get; set; }
public HCNViewModel()
    HCNModel = new HCNModel();
    SnapOnCommand = new RelayCommand<object>((p) => true, (p) =>
        List<ObjectId> explodedObjectIds;
        HCNModel.DuplicateAndExplode(out explodedObjectIds);
        _duplicatedObjectIds.AddRange(explodedObjectIds);
    SnapOffCommand = new RelayCommand<object>((p) => true, (p) =>
        List<ObjectId> explodedObjectIdsToRemove = new List<ObjectId>();
        using (Transaction tr = doc.TransactionManager.StartTransaction())
            foreach (var objectId in _duplicatedObjectIds)
                Entity ent = tr.GetObject(objectId, OpenMode.ForRead) as Entity;
                if (ent != null && ent.OwnerId != ObjectId.Null)
                    explodedObjectIdsToRemove.Add(objectId);
            tr.Commit();
        HCNModel.DeleteExplodedObjects(explodedObjectIdsToRemove);
        foreach (var objectIdToRemove in explodedObjectIdsToRemove)
            _duplicatedObjectIds.Remove(objectIdToRemove);
Accepted solutions (3)
Replies (11)
Message 2 of 12
_gile
Do you show the  interface as modal dialog (Application.ShowModalWindow) or a a modeless dialog (Application.ShowModelessWindow or using a PaletteSet)?
Gilles Chanteau
GileCAD
GitHub
Message 3 of 12
traiduong014969
No, I've created a button on the ribbon tab, and when I click on it, the window view appears. Then, I click a button in the window view. I want to be able to execute other commands while the window view is still open, rather than having to close it.
Message 4 of 12
ActivistInvestor
You didn't answer @_gile 's question.
You need to show how you are showing the Window when you click the button on the Palette.
To do anything while a window is visible you must show the window modelessly (using Application.ShowModelessWindow()). If you show the window by calling ShowModalWindow(), it blocks and will not allow you to do anything until the Window is closed.
Message 5 of 12
traiduong014969
This is the code to display the menu. However, I'm unsure how to modify it to enable other commands without closing the window. Could you please assist me in fixing it?
public class Ribbon : IExtensionApplication
    public void Initialize()
        try
            if (ComponentManager.Ribbon != null)
                CreateMenu();
            else
                Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSetCreated += new EventHandler(RibbonServices_RibbonPaletteSetCreated);
        catch { }
    private void RibbonServices_RibbonPaletteSetCreated(object sender, EventArgs e)
        RibbonPaletteSet_Loaded
        Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.Load += new Autodesk.AutoCAD.Windows.PalettePersistEventHandler(RibbonPaletteSet_Loaded);
    private void RibbonPaletteSet_Loaded(object sender, PalettePersistEventArgs e)
        CreateMenu();
Message 6 of 12
ActivistInvestor
The code you posted is not the code that shows the window when the user clicks the button on the pallet set.
That is what you need to show.
Message 7 of 12
traiduong014969
maybe this code. I have created to input on ribbon button
or
public class SendCommand : ICommand
event EventHandler ICommand.CanExecuteChanged
add { }
remove { }
public bool CanExecute(object parameter) { return true; }
public void Execute(object parameter)
if (parameter is RibbonCommandItem btn)
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
doc.SendStringToExecute((string)btn.CommandParameter + " ", true, false, true);
Message 8 of 12
ActivistInvestor
ShowDialog() displays a modal window that must be closed before you can do anything. If you want the window to remain open while you execute commands or something else, you have to use the ShowModelessWindow() method of the Application object.
Message 9 of 12
traiduong014969
es, I tested this code, and it works. However, when I click the button with the ICommand "Snapon," lines of code appear with errors.
Message 10 of 12
_gile
To be able to modify the active document from a modeless UI, you need to lock the document.
See this topic.
using (doc.LockDocument())
    // do your stuff
Gilles Chanteau
GileCAD
GitHub
Message 11 of 12
ActivistInvestor
Download this file and add it to your project.
Then, make the following changes to your code:
/// change this line:
SnapOnCommand = new RelayCommand<object>((p) => true, (p) => .....
/// To this:
SnapOnCommand = new DocumentRelayCommand<object>((p) => true, (p) => ....
/// Change this line:
/// To this:
SnapOffCommand = new DocumentRelayCommand<object>((p) => true, (p) =>
If you make these changes, then you do not have to manually lock the document, and your code will behave like a command WRT document locking and UNDO/REDO, and your command will correctly not be available when there is no active document.
Message 12 of 12
traiduong014969
@ActivistInvestor , @_gile . Thank you for your help
Finally this code work for me
