CommandMethod CommandFlags default
pfluegge30167
pfluegge30167
Do you know the default CommandFlags of this simple command [CommandMethod("myCommandName")] ?
I want to extend commands with helpfile, so I need to specify CommandFlags like this
[CommandMethod(null, "myCommand", null, commandFlags, null, "myHelpFile.chm", "")].
_gile
As far as I know The CommandFlags default is 0 (i.e. CommandFlags.Modal).
See the docs for CommandFlags Enumeration (.NET) and AcEdCommand::commandFlags (C++).
Gilles Chanteau
GileCAD
GitHub
kerry_w_brown
[AttributeUsage(AttributeTargets.Method, AllowMultiple=true, Inherited=false)]
public sealed class CommandMethodAttribute : Attribute, ICommandLineCallable
    // Methods
    public CommandMethodAttribute(string globalName);
    public CommandMethodAttribute(string globalName, CommandFlags flags);
    public CommandMethodAttribute(string groupName, string globalName, CommandFlags flags);
    public CommandMethodAttribute(string groupName, string globalName, string localizedNameId, CommandFlags flags);
    public CommandMethodAttribute(string groupName, string globalName, string localizedNameId, CommandFlags flags, string helpTopic);
    public CommandMethodAttribute(string groupName, string globalName, string localizedNameId, CommandFlags flags, Type contextMenuExtensionType);
    public CommandMethodAttribute(string groupName, string globalName, string localizedNameId, CommandFlags flags, Type contextMenuExtensionType, string helpFileName, string helpTopic);
    // Properties
    public virtual string HelpTopic { get; }
    public virtual string HelpFileName { get; }
    public virtual Type ContextMenuExtensionType { get; }
    public virtual CommandFlags Flags { get; }
    public virtual string GroupName { get; }
    public virtual string LocalizedNameId { get; }
    public virtual string GlobalName { get; }
These are the attribute signatures ( from reflection )
and the main method
        this.m_groupName = groupName;
        this.m_globalName = globalName;
        this.m_localizedNameId = localizedNameId;
        this.m_flags = flags;
        this.m_contextMenuExtensionType = contextMenuExtensionType;
        this.m_helpFileName = helpFileName;
        this.m_helpTopic = helpTopic;
added:
@_gile  beat me 🙂
Regards
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
pfluegge30167
rtfm 🙂
Many thanks.
