CommandFlags in LispFunction
ahmedshawkey95
ahmedshawkey95
Hi
I'm using LispFunction to enable passing parameters. but when I tried to work with multiple documents (close one and open other one) inside the LispFunction, AutoCAD throws exception document is busy.
In CommandMethod I was using CommandFlags.Session to fix that. but i couldn't find an alternative in LispFunction.
         [LispFunction("PRINTDWGS")]
        public static void PrintDWGs(ResultBuffer rbArgs)
              Application.DocumentManager.CloseAll();
             Document doc = Application.DocumentManager.Open("C:\\test.dwg");
_gile
AutoLISP runs per-document only.
You can open an existing document or create a new one from a LISP function, but this function cannot continue its execution in this document. This stands for built-in functions as for user defined functions.
Gilles Chanteau
GileCAD
GitHub
