command can't stop
command can't stop
command can't stop
Hi,guys. I come across an amazing problem. I creat a command "jtops".In vs.net, I debug the command,it runs well. But when I pack my codes into a installer program and install it, run the command "jtops", promblem is coming.The comand can't stop.Just like you press the Enter key,let it run again and again.At last,the autocad breaks up. Is there anyone who can give me some hints?
Thanks a lot.
chiefbraincloud
The only thing I see is that you aren't using your selection filter. You have to pass it to the GetSelection function.
I don't see anything that would cause it to loop.
The command works fine for me (assuming you only select a block-per Tony's comment)
Perhaps it has something to do with how the command is being installed via your packaged installer.
Thanks, all. The problem is relevant to another dll.Now, I solve it.
