combine e-transmits into 1 zip-file.
stefanveurink68AXD
stefanveurink68AXD
Not sure if this is right place to place this question:
What I want is to combine multiple drawings into 1 e-transmit.
For explantion: I've got 20 drawings, all referring to combinations of 15 x-refs. So, in my directory I've got a total of 35 dwg-files. When I want to send those as e-transmits, I now have to create 20 separate e-transmits, all with their own x-ref files, resulting in a total of 300 dwg files that are sent. Also, there will be sent 20 plotstyle tables, text-fonts, and more.
Would be way nicer if I could just sent 1 zipfile, with 20 drawings, and 15 x-refs, 1 plotstyle table, and one font, etc.
Is this possible? How? I know .net can make the seperate e-transmits (for example) but is it also possible to do this in a smarter way?
3wood
Yes it is possible.
You can add all drawing sheets into a sheet set and then use Sheet Set Manager to eTransmit them into one singe Zip file which only have one copy of each xref.
