Coding with Python3
Coding with Python3
Tony_Gibbs
Coding with Python3
Tony_Gibbs
Is there anybody who can help with providing links to information about programming in Autocad using Python.
I think it is Iron Python I need to use.
johnjmbennett
not an expert on programming, but think the
Closest for this if I’m advance steel would by the Dynamo extension and commands.
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU...
John Bennett
_gile
You can access to the AutoCAD COM/ActiveX API with pyautocad.
To access to the .NET API, you have to use IronPython but it seems to be not so trivial (see this topic).
Gilles Chanteau
GileCAD
GitHub
gleeuwdrent
If you are Civil3D user, you can also use CivilConnection: https://github.com/Autodesk/civilconnection. This enables both AutoCAD and Civil3D API for Python use.
