Code set image does not respect size
m_benigno
m_benigno
Hello, i am trying to change the icon of a ribbon button at runtime, even tho it works, it tries to display the icon as a 32x32 instead of 16x16, button is created via cui editor and set to SmallWithText,  and icon is set from a function called from a command like following:
            var ribbon = ComponentManager.Ribbon;
            var togglePipingModeButton = ribbon?.FindItem("TogglePipingModeButton", false) as RibbonButton;
            var isDarkTheme = Application.GetSystemVariable("COLORTHEME").ToString() == "0";
            var imageName = PipCmnApp.PipingCommonSettings.AdvancedPipingMode ? (isDarkTheme ? "advancedpipingmode_dark" : "advancedpipingmode_light") : (isDarkTheme ? "simplepipingmode_dark" : "simplepipingmode_light");
            var uri = new Uri($"pack://application:,,,/PipCmn;component/Resources/ribbon/{imageName}.ico", UriKind.Absolute);
            togglePipingModeButton.Size = RibbonItemSize.Standard;
            var image = new BitmapImage(uri);
            togglePipingModeButton.Image = image;
            togglePipingModeButton.Text = PipCmnApp.PipingCommonSettings.AdvancedPipingMode ? "Modalità Avanzata" : "Modalità Semplificata";
this does indeed change the icon as said before, but as said, only shows the top-left "quadrant" of the 32x icon instead of scaling it to 16x
tried this with both 16x png and 32x png and had the same result, tried switching to ico but nothing changed.
DYH_
To manually adjust the size
Bitmap resizedBitmap = new Bitmap(originBitmap.GetThumbailImage(width,height,null,Intptr.zero);
The size is related to your screen's scale, meaning the  width & height must be multiplied by this scale factor to get the final size.
var scale = Graphics.FromHwnd(Application.MainWindow.Handle).DpiX/96f;
 then
var bi = new BitmapImage();
bi.BeginInit();
using var ms = new MemoryStream();
resizedBitMap.Save(ms,ImageFormat.Png);
ms.Seek(0,SeekOrigin.Begin);
bi.StreamSource = ms;
bi.CacheOption = BitmapCaccheOption.OnLoad;
bi.EndInit();
ribbonButton.Image = bi;
The code above was written without an IDE ,  if you spot any errors, feel free to tweak it a bit.
m_benigno
It did indeed work, a shame tho that i have to manually adjust the size even tho the icon is already in the desired size.
Nonetheless thanks for the answer!
