CloseAndSave()method not saving the file
Mohamed_Arshad
Advisor Advisor
Mohamed_Arshad
Hi Guys!!
      I need to save the opened document, I use CloseAndSave() method but it not saving the file. Can anyone explain me how the above method works.
@_gile @Norman_Yuan @ActivistInvestor
Mohamed Arshad K
Software Developer (CAD & BIM)
_gile
You could use Database.SaveAs before closing the document.
Gilles Chanteau
GileCAD
GitHub
Mohamed_Arshad
HI @_gile
   Thank you so much for quick reply, As you mentioned I have used SaveAs also it is working fine. But I need to know how to use SaveAndClose() Method so that I get an additional information.
Mohamed Arshad K
_gile
I cannot help you further without seeing any code and having some information on the context this is run.
This minimalist test command works as expected:
[CommandMethod("Test", CommandFlags.Session)]
public static void Test()
    var doc = Application.DocumentManager.MdiActiveDocument;
    doc.CloseAndSave(@"F:\Drawings\Test.dwg");
Gilles Chanteau
GileCAD
GitHub
Mohamed_Arshad
HI @_gile
  I forget to Change the Command Flags, Now its working fine. Thank you so much 🙂
Mohamed Arshad K
