close polygons
close polygons
close polygons
I want to write a routine to check if then first point of a polyline en the last point is the same. If yes and polyline is not closed:  delete last vertice and close polyline. My code crashes at
Dim obj As Object = myObjID.GetObject(OpenMode.ForRead, False)
when there are more than one polygons.
What is wrong.
In the next step I want to expand my code to all polylines (polyline3d, polyline2d, polyline and lwpolyline) : the code crashes also when I add this to the typed value
 <CommandMethod("Closepolygons")>
        Public Shared Sub Closepolygons()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim filterlist As TypedValue() = New TypedValue(1) {}
            filterlist(0) = New TypedValue(0, "LWPOLYLINE")
            filterlist(1) = New TypedValue(8, "*")
            Dim filter As SelectionFilter = New SelectionFilter(filterlist)
            Dim selRes As PromptSelectionResult = ed.SelectAll(filter)
            Dim myObjIDs As ObjectIdCollection
            If selRes.Status = PromptStatus.OK Then
                ' If per.Status = PromptStatus.OK Then
                myObjIDs = New ObjectIdCollection(selRes.Value.GetObjectIds)
                Dim tr As Transaction = db.TransactionManager.StartTransaction()
                For Each myObjID In myObjIDs
                    Using tr
                        Dim lwp As Polyline = TryCast(obj, Polyline)
                        If lwp IsNot Nothing Then
                            Dim vn As Integer = lwp.NumberOfVertices
                            Dim point1, point2 As Point2d
                            point1 = lwp.GetPoint2dAt(0)
                            point2 = lwp.GetPoint2dAt(vn - 1)
                            If point1 = point2 Then
                                'delete last vertex
                                Dim obj2 As Object = myObjID.GetObject(OpenMode.ForWrite, False)
                                lwp.RemoveVertexAt(vn - 1)
                                If Not lwp.Closed Then
                                    lwp.Closed = True
                                lwp.UpgradeOpen()
                                lwp.RecordGraphicsModified(True)
                        tr.Commit()
                    End Using
                Next
        End Sub
_gile
You have to make the For Each loop within the Using Transaction statement because the way you do it, the Transaction is Disposed at the first iteration when you do End Using.
Also, I'm not very cumfortable with VB but why do you do:
knowing that GetObject returns a DBObject instant and, in this case, the DBObject is always a Polyline due to the selection filter ?
You could directly do:
Dim lwp As Polyline = DirectCast(myObjID.GetObject(OpenMode.ForRead, False), Polyline)
You should be able to get some inspiration from this working code.
        [CommandMethod("CLOSEPOLYGONS")]
        public static void Closepolygons()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var filter = new SelectionFilter(new[] { new TypedValue(0, "LWPOLYLINE") });
            var selection = ed.SelectAll(filter);
            if (selection.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                foreach (SelectedObject obj in selection.Value)
                    var pline = (Polyline)tr.GetObject(obj.ObjectId, OpenMode.ForRead);
                    int lastIndex = pline.NumberOfVertices - 1;
                    if (pline.GetPoint2dAt(0).IsEqualTo(pline.GetPoint2dAt(lastIndex)))
                        tr.GetObject(obj.ObjectId, OpenMode.ForWrite);
                        pline.RemoveVertexAt(lastIndex);
                        pline.Closed = true;
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
thanks, this codes works perfect and how can I make it work for a polyline3D ?
_gile
Here's an example with Polyline3d.
        [CommandMethod("CLOSEPOLYGONS3D")]
        public static void Closepolygons3d()
                new TypedValue(0, "POLYLINE"),
                new TypedValue(-4, "&"),
                new TypedValue(70, 8)});
                return;
                    var pline = (Polyline3d)tr.GetObject(obj.ObjectId, OpenMode.ForRead);
                    if (pline.PolyType != Poly3dType.SimplePoly)
                        continue;
                    ObjectId vertexId = ObjectId.Null;
                    foreach (ObjectId id in pline)
                        vertexId = id;
                    var vertex = (PolylineVertex3d)tr.GetObject(vertexId, OpenMode.ForRead);
                    if (vertex.Position.IsEqualTo(pline.StartPoint))
                        tr.GetObject(vertexId, OpenMode.ForWrite);
                        vertex.Erase();
                        tr.GetObject(pline.ObjectId, OpenMode.ForWrite);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Thanks !  Works great !
