Cloning a database from an existing database and retaining dimension styles etc
BKSpurgeon
BKSpurgeon
Hi all
I am trying to copy certain objects from my current drawing into a new one. I am using the code contained here: https://adndevblog.typepad.com/autocad/2012/09/copying-deepcloning-from-one-drawing-to-another-using...
Basically I'm using WblockCloneObjects to copy objects from one drawing to another. But the problem is that the new drawing does not retain all the items contained in the source database: e.g. dimension styles, styling, layers, certain block definitions etc
Is there a way to ensure that all of those items are also cloned? In other words, I want the new database exactly the same as the old, except for what appears in the model space - and I have object ids for those items which I want in the model space.
Any advice would be much appreciated. Thank you!
Ben
Alexander.Rivilis
It is look like easy to duplicate source dwg-file, open it and erase all entities in ModelSpace.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
_gile
If you absolutely want to use WblockCloneObjects  (even the route suggested by @Alexander.Rivilis shuld be much mor simple), you have to clone the contents of all tables in the source file to the corresponding table in the destination file.
Gilles Chanteau
GileCAD
GitHub
