Click the dwg then get the Infomation of Entity
when I clicke the entity in dwg, I want to get that entity infomation, like a image.
So, I was using the event in Editor.
Editor ed = doc.Editor;
ed.PromptedForSelection += edPromptForSelection;
        private void edPromptForSelection(object sender, PromptSelectionResultEventArgs e)
            Editor ed = sender as Editor;
            PromptSelectionResult psr = e.Result;
            if (psr.Status != PromptStatus.OK) return;
            ObjectId[] objArr = psr.Value.GetObjectIds();
            // 레이어를 생성하고, 점만 출력한다.
            using (docLock = doc.LockDocument())
                using (tr = db.TransactionManager.StartTransaction())
                    foreach (ObjectId Id in objArr)
                        Entity ent = tr.GetObject(Id, OpenMode.ForRead) as Entity;
            ed.SetImpliedSelection(objArr);
It was working what I thought but Called the Event many times.... maybe 4?
I just want to call one by one clicked.
so, To release or Clear the selection list,
I used the
But It cannot fix the problem.
norman.yuan
You did not show whole picture of how your code is loaded into AutoCAD and how it would be triggered.
However, if your goal is that after your code is loaded/enabled, whenever user selects an Entity in AutoCAD editor, your form pops up (modal or modeless?), you may want to think again: when user works with AutoCAD, he/she would click on AutoCAD editor/entities very often (consciously or unconsciously) for any purpose, do you want to annoy the user by keeping showing up your form?
You'd be better off using custom context menu when user right-click an entity, or using custom double-click event handler to give user the chance to explicitly/consciously show the form.
To use custom context menu, look into these article:
http://through-the-interface.typepad.com/through_the_interface/2007/05/adding_a_contex.html
http://through-the-interface.typepad.com/through_the_interface/2008/11/displaying-a-co.html
For custom double-click handling, this could be of help:
http://drive-cad-with-code.blogspot.ca/2013/03/update-custom-double-click-action-using.html
Norman Yuan
Drive CAD With Code
Thanks, norman.yuan.
