Changing the "FILLET" radius of a polyline
youssefGC
Message 1 of 8
youssefGC
Hello Forums,
I am working on a function that allows modifying the fillet radius between two segments of a polyline. For instance, if the current radius is 120 (image 1), we want to change it to a value of 250 (image 3).
So, initially, my idea is to transform the polyline into one with broken lines (no fillet / image 2) and then apply "FILLET" with the new radius value.
The problem I found is in the evaluation of the intersection vertex (point A in the photo).
Thank you.
Replies (7)
Message 2 of 8
ActivistInvestor
You can use Polyline.GetLineSegment2dAt() to get the two adjacent line segments and then call IntersectWith() to find the point you need.
Message 3 of 8
youssefGC
Thank you for the reply.
In my understanding, using "Polyline.GetLineSegment2dAt()" allows retrieving a line segment for a given starting index, and the endpoint is the next point in the polyline. If I apply this to retrieve both segments (I) and (II), I cannot perform the intersection since both segments require an extension.
Message 4 of 8
ActivistInvestor
You can create two instances of the Line2d class from the endpoints of the 2 line segments, and intersect those.
Message 5 of 8
youssefGC
I made a mistake in the second argument of the "IntersectWith" method. Instead of using "Intersect.ExtendBoth," I had used "OnBothOperands." Here is an excerpt of the corrected code that works well for me:
for (int i = 1; i < tempPline.NumberOfVertices-1; i++)
                    if (tempPline.GetBulgeAt(i)!=0)
                        Line L1 = new Line(tempPline.GetPoint3dAt(i-1), tempPline.GetPoint3dAt(i));
                        Line L2 = new Line(tempPline.GetPoint3dAt(i+1), tempPline.GetPoint3dAt(i+2));
                        Point3dCollection intPoints = new Point3dCollection();
                        L1.IntersectWith(L2, Intersect.ExtendBoth, intPoints, IntPtr.Zero, IntPtr.Zero);
                        if (intPoints.Count>0)
                            lstPts.Add(intPoints[0]); // Add to list
Message 6 of 8
ActivistInvestor
Except that your code is creating new database objects and not disposing them or adding them to a database.
It also relies on an assumption that the polylines start and end with line segments rather than arc segments.
Message 7 of 8
youssefGC
The overall program precisely deletes the old polyline and adds the new one at the end.
The starting point is always a line (bulge = 0). I forgot to mention this detail in the original post.
Message 8 of 8
ActivistInvestor
I was referring to the two line entities that your code creates:
