Changing Project Build Configuration to Debug mode
07:07 AM
From my DLL project I have succeded in making AutoCAD launch by pressing F5 from VB.net IDE (Visual Studio 2008)
en route to try to make debugging of the DLL easier ...
... however one last obstacle is currently in the way and the obstacle is that for some reason when I hit F5 and AutoCAD is launched
my breakpoints are not recognized at all... and program runs from start to finish instead of allowing me to debug ...
It issues a strange message which says "The following module was built either with optimizations enabled or without debug information... to debug this module, change its project build configuration to Debug mode..." and it is all weird because as far as I know I am not in release mode .. but in debug mode (anyhow I am relatively new to Visual Studio .NET so I am thinking that my impression could be that I am in debug mode when in actuality I maybe in release mode)...
Here is why I think I am debug mode ...
1. From Solution explorer ... when I click on the Solution Name and view its properties ... the Active config property says Debug|Any CPU
2. When I look at the properties of the project and look at the compile tab it says that the Configuration is Active (Debug) and under Platform it says Active (Any CPU).
3. Under the Advanced Compile Options of Compile Tab from project properties ... Enable optimizations is UNchecked ...
Anyhow with all the settings mentioned above it seems that I have everything okay but then the message above proves otherwise ... and so at this point I know that I am still missing something ... like a setting somewhere... wondering what else do you think am I still missing?
As additional info...there are seven projects in the solution and it is the main one (the one that I set as startup project) whose properties I refer to in all the paragraphs above.
Thanks so much for all the kind help you could give....
Gratefully,
Matt
Gratefully,
Matt
