Change hatchstyle of hatch when creating a new hatch by pickpoint
I 've been lately trying to create an hatch with C# with the hatchstyle set to outer.I have used the following code
from this blog: https://www.keanw.com/2010/06/creating-transparent-hatches-in-autocad-using-net.html
The code is the same with the only difference is that i set hatchstyle to outer and i append all loops as outermost:
public class Commands { static int _index = 1; [CommandMethod("TBH")] public void TraceBoundaryAndHatch() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; // Select a seed point for our boundary PromptPointResult ppr = ed.GetPoint("\nSelect internal point: "); if (ppr.Status != PromptStatus.OK) return; // Get the objects making up our boundary DBObjectCollection objs = ed.TraceBoundary(ppr.Value, false); if (objs.Count > 0) { Transaction tr = doc.TransactionManager.StartTransaction(); using (tr) { // We'll add the objects to the model space BlockTable bt =(BlockTable)tr.GetObject(doc.Database.BlockTableId,OpenMode.ForRead); BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace],OpenMode.ForWrite); // Add our boundary objects to the drawing and // collect their ObjectIds for later use ObjectIdCollection ids = new ObjectIdCollection(); foreach (DBObject obj in objs) { Entity ent = obj as Entity; if (ent != null) { // Set our boundary objects to be of // our auto-incremented colour index ent.ColorIndex = _index; // Set our transparency to 50% (=127) // Alpha value is Truncate(255 * (100-n)/100) ent.Transparency = new Transparency(127);
// Add each boundary object to the modelspace // and add its ID to a collection ids.Add(btr.AppendEntity(ent)); tr.AddNewlyCreatedDBObject(ent, true); } } // Create our hatch Hatch hat = new Hatch(); // Solid fill of our auto-incremented colour index hat.SetHatchPattern(HatchPatternType.PreDefined,"SOLID"); hat.ColorIndex = _index++; hat.HatchStyle = HatchStyle.Outer; // Set our transparency to 50% (=127) // Alpha value is Truncate(255 * (100-n)/100) hat.Transparency = new Transparency(127); // Add the hatch to the modelspace & transaction ObjectId hatId = btr.AppendEntity(hat); tr.AddNewlyCreatedDBObject(hat, true); // Add the hatch loops and complete the hatch
hat.Associative = true; foreach (ObjectId id in ids)
var newIds = new ObjectIdCollection();
newIds.Add(id);
hat.AppendLoop(HatchLoopTypes.Outermost, newIds);
} hat.EvaluateHatch(true); tr.Commit(); } } } }
The problem is that setting hatchstyle to outer does not show any results. I get the following:
Setting the looptype to default results in the boundaries being created but nothing hatched.
I 'd like to achieve this result, but it seems to me that the hatchstyle is just being ignored:
Expected result
Any kind of help would be greatly appreciated. I just cant figure out what the catch is.
Thanks everyone in advance.
