Change Attributes of a block nested in dynamic block
jplujan
Message 1 of 13
jplujan
Hi:
I want to change the attributes of a block contained in a dynamic block.
I have managed to change the attributes when the block is static.
I leave the code I am using.
 Sub UpdateAtts1(BlockID As Object, NombreBloqueHijo As String, prefijo As String, tagstring As String, contador As Integer)
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim i As Integer = contador
        Using docloc As DocumentLock = doc.LockDocument
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim br As BlockReference = CType(tr.GetObject(BlockID, OpenMode.ForRead), BlockReference)
                Dim btr As BlockTableRecord = Nothing
                If br.IsDynamicBlock Then
                    Dim btrHijo As BlockTableRecord = CType(tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                    For Each id As ObjectId In btrHijo
                        If id.ObjectClass.Name = "AcDbBlockReference" Then
                            Dim brHijo As BlockReference = DirectCast(tr.GetObject(id, OpenMode.ForRead), BlockReference)
                            If brHijo.Name = NombreBloqueHijo Then
                                For Each attId As ObjectId In brHijo.AttributeCollection
                                    Dim attRef As AttributeReference = DirectCast(tr.GetObject(attId, OpenMode.ForWrite), AttributeReference)
                                    If attRef.Tag = tagstring Then
                                        attRef.UpgradeOpen()
                                        attRef.TextString = prefijo & i
                                        i += 1
                                        Exit For
                                Next
                    Next
                Else
                    btr = CType(tr.GetObject(br.BlockTableRecord, OpenMode.ForWrite), BlockTableRecord)
                                        i += 1
                                        Exit For
                                Next
                    Next
                tr.Commit()
            End Using
        End Using
        ed.Regen()
    End Sub
Thank you
Greetings
Replies (12)
Message 2 of 13
Norman_Yuan
Well, you did not describe how the property/properties in the dynamic block definition is designed or how it/they behave, especially how it could affect the said BlockReference in the dynamic block definition. For example, if the block definition has a Visibility parameter that could make the BlockReference element shown/hidden, then the nested block reference could only be found in the anonymous block definition.
That is, in your code:
    Dim btrHijo As BlockTablerecord = CType(tr.GetObject(br.DynamicBlockTableRecord, ...
Else
Should be
    Dim btrHijo As BlockTablerecord = CType(tr.GetObject(br.BlockTableRecord, ...
Else
Norman Yuan
Drive CAD With Code
Message 3 of 13
jplujan
Thanks for your quick response
I just made your change and it doesn't update the attributes.
I enclose an example drawing I want to renumber the blocks called "ET-V" in the code "NombreBloqueHijo" with a consecutive order.
Thanks, again
Message 4 of 13
Norman_Yuan
Well, I have no problem update the nested block reference's attribute in both the static block and dynamic blocks in your sample drawing with the exactly the same code, as following:
    public class MyCommands
        [CommandMethod("AttCmd")]
        public static void RunMyCommand()
            var doc = CadApp.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var blkId = SelectBlock(ed);
            if (!blkId.IsNull)
                UpdateNestedBlockAttributes(blkId);
                // Regen is needed, since the block definition is update
                // (that is, the nested block reference is in the block definition)
                ed.Regen();
        private static ObjectId SelectBlock(Editor ed)
            var opt = new PromptEntityOptions("\nSelect block:");
            opt.SetRejectMessage("\nInbalid selection.");
            opt.AddAllowedClass(typeof(BlockReference), true);
            var res = ed.GetEntity(opt);
            if (res.Status== PromptStatus.OK)
                return res.ObjectId;
            else
                return ObjectId.Null;
        private static void UpdateNestedBlockAttributes(ObjectId blkId)
            using (var tran = blkId.Database.TransactionManager.StartTransaction())
                var blkRef = (BlockReference)tran.GetObject(blkId, OpenMode.ForRead);
                var blkDef = (BlockTableRecord)tran.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead);
                foreach (ObjectId id in blkDef)
                    if (id.ObjectClass.DxfName.ToUpper()=="INSERT")
                        var nestedBlkRef = (BlockReference)tran.GetObject(id, OpenMode.ForRead);
                        if (nestedBlkRef.AttributeCollection.Count>0)
                            int index = 1;
                            foreach (ObjectId attId in nestedBlkRef.AttributeCollection)
                                var attref = (AttributeReference)tran.GetObject(attId, OpenMode.ForWrite);
                                attref.TextString = $"NUMBER: {index}";
                                index++;
                tran.Commit();
Below is the video clip showing the code effect:
Norman Yuan
Drive CAD With Code
Message 5 of 13
Norman_Yuan
I have no problem to update attribute values in block reference that is nested in a block definition, be it static or dynamic, with the exactly the same code:
            if (!blkId.IsNull)
                ed.Regen();
            else
                            int index = 1;
                                index++;
                tran.Commit();
See the video clip below for the code effect:
Norman Yuan
Drive CAD With Code
Message 6 of 13
jplujan
Hi:
Thanks for your reply
I'm going to try it
Thanks again
Message 7 of 13
jplujan
Hi
The code works for all nested blocks.
I have modified the code so that it only renumber the block called "ET-V" and it does not work
I leave the new code and a new drawing
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Public Class Mycommands
    <CommandMethod("AttCmd")>
    Public Shared Sub RunMyCommand()
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim ed = doc.Editor
        Dim blkId = Mycommands.SelectBlock(ed)
        If Not blkId.IsNull Then
            Mycommands.UpdateNestedBlockAttributes(blkId)
            ' Regen is needed, since the block definition is update
            ' (that is, the nested block reference is in the block definition)
            ed.Regen
    End Sub
    Private Shared Function SelectBlock(ByVal ed As Editor) As ObjectId
        Dim opt = New PromptEntityOptions("" & vbLf & "Select block:")
        opt.SetRejectMessage("" & vbLf & "Invalid selection.")
        opt.AddAllowedClass(GetType(BlockReference), True)
        Dim res = ed.GetEntity(opt)
        If (res.Status = PromptStatus.OK) Then
            Return res.ObjectId
        Else
            Return ObjectId.Null
    End Function
    Private Shared Sub UpdateNestedBlockAttributes(ByVal blkId As ObjectId)
        Dim tran = blkId.Database.TransactionManager.StartTransaction
        Dim blkRef = CType(tran.GetObject(blkId, OpenMode.ForRead), BlockReference)
        Dim blkDef = CType(tran.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
        For Each id As ObjectId In blkDef
            If (id.ObjectClass.DxfName.ToUpper = "INSERT") Then
                Dim nestedBlkRef = CType(tran.GetObject(id, OpenMode.ForRead), BlockReference)
                ' Block Name "ET-V"
                If nestedBlkRef.Name = "ET-V" Then
                    If (nestedBlkRef.AttributeCollection.Count > 0) Then
                        Dim index As Integer = 1
                        For Each attId As ObjectId In nestedBlkRef.AttributeCollection
                            Dim attref = CType(tran.GetObject(attId, OpenMode.ForWrite), AttributeReference)
                            attref.TextString = "ET-{index}"
                            index = (index + 1)
                        Next
        Next
        tran.Commit
    End Sub
End Class
Thank you
Message 8 of 13
Norman_Yuan
I am sure that you know the ONLY change you made is this:
If nestedBlkRef.Name = "ET-V" Thern
So, if the code does not work as expected, then that change is the reason: BECAUSE the block reference is dynamic, so, its "Name" property is very likely not the same as the dynamic block definition's Name, rather it is the name of an anonymous block definition, which is generated by AutoCAD when a dynamic property value is set to a value different from the default value. So, if you need to determine if the dynamic block reference is the target one (containing target attributes) by its name, you need to find its dynamic block definition's name. Some thing like:
For Each ....
    If id.ObjectClass.DxFName.ToUpper = "INSERT" Then
        Dim nestedBr = CType(tran.GetObject(
                 nestedBlkRef.DynamicBlockTableRecord, OpenMode.ForRead), BlockTableRecord)
        Dim blkName As String = nestedBlkBr.Name
        If blkName.ToUpper = "ET-V" Then
            '' Now you have really identified the target block reference
            '' loop through its attributes and do update according to its tag here.
If you do know/are sure that there is not other block in the drawing that contains a nested block reference, which in turn contains attributes with specific TAGs (chances are very low, I'd think), you probably do not need to test the nested block reference's effective block name.
Norman Yuan
Drive CAD With Code
Message 9 of 13
jplujan
Hello again.
I can not get the result, I do not want to take more of your time on the subject, I think the solution is close, I will continue investigating.
Thank you
Message 10 of 13
Norman_Yuan
Well, I just added a couple of lines of code to test block reference's "effective name", as I suggested, and it works as expected. Here are the working code and video clip showing the effect:
            if (!blkId.IsNull)
                ed.Regen();
            else
                int index = 1;
                    if (id.ObjectClass.DxfName.ToUpper() == "INSERT")
                        var nestedBlkDef = (BlockTableRecord)tran.GetObject(
                            nestedBlkRef.DynamicBlockTableRecord, OpenMode.ForRead);
                        if (nestedBlkDef.Name.ToUpper() == "ET-V")
                            if (nestedBlkRef.AttributeCollection.Count > 0)
                                    var attref =
                                    switch(attref.Tag.ToUpper())
                                        case "NUMVALVULA":
                                            attref.TextString =
                                                $"VAL-{index.ToString().PadLeft(3,'0')}";
                                            break;
                                        case "DESCRIPCION":
                                            attref.TextString =
                                                $"DESCRIPCION: {index.ToString().PadLeft(3, '0')}";
                                            break;
                                        case "ELEMENTO":
                                            attref.TextString =
                                                $"ELEMENTO: {index.ToString().PadLeft(3, '0')}";
                                            break;
                                    index++;
                tran.Commit();
Norman Yuan
Drive CAD With Code
Message 11 of 13
jplujan
Hi
Very grateful for your dedication.
Now if it works correctly, what I have realized is that if I need to edit the main dynamic block, when it records it it does not keep the changes made in the children.
Thank you
Message 12 of 13
Norman_Yuan
I am not sure what does "... edit the main dynamic block, when it records it it does not keep the changes made in the children..." mean. But having dynamic block nested inside a dynamic block would not be a good practice as far as I can see.
Norman Yuan
Drive CAD With Code
Message 13 of 13
jplujan
Hi:
I understand, we left the subject for ditch.
Thank you so much for everything
