center of block
center of block
center of block
Hi, Help needed in finding the center of a selected block. Thanks & Regards Sanjay Pandey
swaywood
hi sanjaymann:
you can use the blockreference's geometricextents.maxpoint & minpoint to get the two corner point, then calculate the center point
inbref.GeometricExtents.MaxPoint
Tried using that but its not falling in the center.
Dim centerX As Double = br.GeometricExtents.MaxPoint.X + br.GeometricExtents.MinPoint.X / 2
Dim centerY As Double = br.GeometricExtents.MaxPoint.Y + br.GeometricExtents.MinPoint.Y / 2
Did i do something wrong?
_gile
Dim centerX As Double = (br.GeometricExtents.MaxPoint.X + br.GeometricExtents.MinPoint.X) / 2
Dim centerY As Double = (br.GeometricExtents.MaxPoint.Y + br.GeometricExtents.MinPoint.Y) / 2
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
OOPs my bad. Didn't put brackets before dividing by Zero.
Thanks a Ton.
