capture right click in getpoint
Message 1 of 9
How to detect right click as response to a getxxx call
The various flavors of PromptStatus dont seem to be the trick,
I see the following about mousegesture in msdn but no clue if this is the
way somehow...any tips?
MouseGesture CutCmdMouseGesture = new MouseGesture(
MouseAction.MiddleClick);
MouseBinding CutMouseBinding = new MouseBinding(
ApplicationCommands.Cut,
CutCmdMouseGesture);
// RootWindow is an instance of Window.
RootWindow.InputBindings.Add(CutMouseBinding);
from acads' lab2(modified)[CommandMethod("selectPoint")]static public void
selectpoint() {while (true){PromptPointOptions prPointOptions = new
PromptPointOptions("Select a point");PromptPointResult prPointRes;Editor ed
= Application.DocumentManager.MdiActiveDocument.Editor;prPointRes =
ed.GetPoint(prPointOptions);//i tried .Other but that didn't fire on right
click//i get "Invalid Point" at the command line...so it didn't throw an
error either//if (prPointRes.Status == PromptStatus.Other)
//{//ed.WriteMessage("Other\n");//break;//}if (prPointRes.Status !=
PromptStatus.OK){ed.WriteMessage("Error\n");break;}else{ed.WriteMessage("You
selected point " + prPointRes.Value.ToString());}}}
Replies (8)
Message 2 of 9
Did you look at the sample I referred you to, and specifically it's use of
the AllowNone property of the PromptPointObjects class?
Also, the code in your post is reformatted and unreadable in my newsreader.
I'm not sure what the current state of the forum software is, but most here
use a newsreader and put code inside of {code} tags to preserve formatting.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"mp" wrote in message
news:6295901@discussion.autodesk.com...
Message 3 of 9
Hi Tony,
Yes i did look at the code, thanks for that,
I missed the part about AllowNone , Will review that again.
That's interesting about the code reformatting, I only use newsreader also
and that's the first i've seen a newsreader munge formatting, I thought that
was only the web interface that did that.
so even in newsreader you need the {code} tags?
will remember that
thanks
mark
"Tony Tanzillo" wrote in message
news:6295971@discussion.autodesk.com...
Message 4 of 9
Thanks Tony, AllowNone did the trick
I have to admit the documentation of that property is obscure to me, but I
see it does what i wanted.
mark
Message 5 of 9
I'm assuming you mean this:
"Gets or sets whether the prompt accepts ENTER as sole input. "
If so, that's not nearly as obscure as some of the stuff I've read in the
docs.
news:6296024@discussion.autodesk.com...
mark
Message 6 of 9
It's not the newsreader itself that's doing the mangling, it's Autodesk's
discussion software. Yes, you need the code tags regardless of how you
post.
news:6296021@discussion.autodesk.com...
Hi Tony,
will remember that
thanks
mark
Message 7 of 9
When using a newsreader such as Outlook Express - set your return to "Plain
Text" instead of HTML and I believe you will be alright. I don't seem to
have any issues doing it this way.
Public Function OpenMDBDatabase(Connect As ADODB.Connection, Name As String)
As Boolean
On Error Resume Next
If Not Connect.State = adStateOpen Then
Connect.Open "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & Name & ";"
If Err Then Exit Function
OpenMDBDatabase = True
End Function
Unless of course this test goes South on me.
Hi Tony,
will remember that
thanks
mark
Message 8 of 9
Right, I've always had it set that way and don't remember having problem
before.
oh well
"Steve" wrote in message
news:6297460@discussion.autodesk.com...
As Boolean
End Function
Hi Tony,
will remember that
thanks
mark
Message 9 of 9
Hi Tony,
I got the same problem? could you please let me know where is the trick?
Thanks very much
Yaqi
