Can't get intersection point using Entity.IntersectWith sometimes
tom.zhengGNS4G
tom.zhengGNS4G
Hi! I'm new to AutoCAD .NET and trying to get the intersection point of 2 lines using Entity.IntersectWith method lately. Usually, it can find the intersection points. but sometimes it doesn't get it when there should be intersection point between 2 lines.  Can' t figured it out why. can someone help or give some suggestions? thx!
Below is my code for test. I iterate each 2 lines in all lines selected by user and draw a circle on every intersection point. I write in c#:
[CommandMethod("Test")]
public void Test()
    Active.UsingTransaction(tr =>
        var lineResult = Selector.GetSelection("\nselect lines: ");  //get user selection
        if (lineResult.Status != PromptStatus.OK) return;
        var lines = new List<Line>();
        foreach (var objId in lineResult.Value.GetObjectIds())
            lines.Add(objId.GetObject(OpenMode.ForRead) as Line);
        for (var i = 0; i < lines.Count; i++)
            if (i + 1 == lines.Count) break;
            for (var j = i + 1; j < lines.Count; j++)
                Line line1 = lines[i], line2 = lines[j];
                var interPts = new Point3dCollection();
                line1.IntersectWith(line2, Intersect.OnBothOperands, interPts, IntPtr.Zero, IntPtr.Zero);
                if (interPts.Count > 0) Draw.DrawCircle(interPts[0], 1);  //draw a circle with radius 1 on intersection point
_gile
Try with LineSegment3d.IntersectWith instead.
        public void Test()
                var lineSegments = lineResult.Value
                    .GetObjectIds()
                    .Select(id => (Line)id.GetObject(OpenMode.ForRead))
                    .Select(line => new LineSegment3d(line.StartPoint, line.EndPoint))
                    .ToArray();
                for (var i = 0; i < lineSegments.Length - 1; i++)
                    for (var j = i + 1; j < lineSegments.Length; j++)
                        var line1 = lineSegments[i];
                        var line2 = lineSegments[j];
                        var interPts = line1.IntersectWith(line2);
                        if (interPts != null)
When you post some code:
  • Use the 'Insert/Edit code sample' button.
  • If the code calls method from external libraries, provide the libraries source or a link to them.
Gilles Chanteau
GileCAD
GitHub
_gile
I should have started there.
Are you sure there is an intersection between these lines (i.e. they are on the same plane)?
Gilles Chanteau
GileCAD
GitHub
tom.zhengGNS4G
I checked all the 'Z' values of line's StartPoint/EndPoint are '0'. Does this mean they are on the same plane?  sorry I'm not familiar with AutoCAD.
_gile
Yes, that means all the lines lies on the XY plane.
Another thing, if the lines are far away from the origin (about x0,000,000 units for x and/or y) there may be an accuracy issue. A workaround is moving all lines closer to the origin, get the intersections and move back the lines (and intsection points).
Gilles Chanteau
GileCAD
GitHub
tom.zhengGNS4G
Thanks for your suggestion! I found that some lines are not on the same plane. The property panel in AutoCAD shows that all lines are on the Z=0 plane. But when I get the position by code it shows that some line's Z value is not 0.
in AutoCAD it shows that all the Z-value is 0.
get the position of same line by code.
so I use a method to transform line to Z=0 plane if it is not.
void transformZAxis(Line line)
    line.UpgradeOpen();
    if (line.StartPoint.Z != 0)
        line.StartPoint = line.StartPoint.TransformBy(Matrix3d.Displacement(new Vector3d(0, 0, -line.StartPoint.Z)));
    if (line.EndPoint.Z != 0)
        line.EndPoint = line.EndPoint.TransformBy(Matrix3d.Displacement(new Vector3d(0, 0, -line.EndPoint.Z)));
    line.DowngradeOpen();
After all the lines transform to the same plane. it successfully get all the intersection points. Thanks again for your advice.
_gile
You could simply do:
    line.UpgradeOpen();
        line.StartPoint = new Point3d(line.StartPoint.X, line.StartPoint.Y, 0.0);
        line.EndPoint = new Point3d(line.EndPoint.X, line.EndPoint.Y, 0.0);
Gilles Chanteau
GileCAD
GitHub
