Can not open BlockTableRecord as OpenMode.ForWrite
nghiabt04
nghiabt04
Currently, I write a program open WPF UserControl as ToolPalette. When I tried to GetObject BlockTableRecord as OpenMode.ForWrite by a button but AutoCAD always turns to be FATAL ERROR shutdown anyway.
When I test this code again in command mode, the code works fine. Anyone have an idea about this situation, please help me.
Thanks a lot!
SENL1362
did you lock the document?
try
using (var docLck = doc.LockDocument())
var db=doc.Database;
using (var tr=db.TransactionManager.StartTransaction())
var blk = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForWrite);
_gile
From Kean Walmsley's blog:
"there’s our important rule of thumb when it comes to implementing a modeless UI: rather than manually locking the current document, it’s safer to define a command – which will implicitly lock the current document – and call that from the UI via SendStringToExecute()."
Gilles Chanteau
GileCAD
GitHub
nghiabt04
Yes, I forgot to lock the document, thanks for your help
