call autocad quickselect dialog from .net api (c#)
I want to call autocad quickselect dialog from my autocad addins by .net api with c#
Autocad 2014
can anyone help?
thanks
_gile
With AutoCAD 2014, you can call the Document.SendStringToExecute() method but it doesn't run synchronously.
if you want if to run synchronously, you can use Tony Tanzillo's (aka DinningPhilosopher) wrapper for the undocumented RunCommand() method see this thread:
http://forums.autodesk.com/t5/net/send-command-executes-after-exiting-command-method/td-p/3882929
Gilles Chanteau
GileCAD
GitHub
thanks, its very good solutions.
in Autocad 2017 it's not work,, any solusion? please>>>
_gile
With AutoCAd 2015 and later you have to use the EditorCommand() method.
var ed = Application.DocumentManager.MdiActiveDocument.Editor;
ed.Command("_qselect");
Gilles Chanteau
GileCAD
GitHub
