C#)DBText alignment error when openning ReadDwgFile Method have modified DBText
Hi.
Please attachment video.
DBtext alignment  is not right when DBText update by ReadDwgFile Method.
Open the drawing can be seen that the change position when DBText TextEdit mode.
ex) DBText Change Method
public void ChangeDBTExt
          Database acCurDB = new Database(false, false);
          acCurDB.ReadDwgFile(filePath, FileOpenMode.OpenForReadAndAllShare, false, "");
          acCurDB.CloseInput(true);
          using (Transaction acTrans = acdoc.TransactionManager.StartTransaction())
               DBText dbtext = acTrans.GetObject(MyFocusedHandle, OpenMode.ForRead) as DBText;
               dbText.UpgradeOpen();
               dbText.TextString = MyString;
               //dbText.AdjustAlignment(acCurDB);
               acTrans.Commit();
So I searched a site to calculate mid alignment (http://www.acadnetwork.com/index.php?topic=311.0)
but this method also fails.
Will you have any way to solve this problem?
Thanks.
I solved that.
Thanks.
Hodw do you solve that? I met this problem. I find that the position property not updated correcty after I change the  textstring.
