C# based on AutoCAD2025 secondary development
Use C# for AutoCAD secondary development, design their own dll plug-in, hope to complete the following functions: read dwg format files, and then the model space in the various blocks to block name save as pictures. But met a lot of problems, may also be the version of the problem, I hope someone can help solve. The code is as follows:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Runtime;
using System;
using System.IO;
using System.Linq;
namespace BlockExporter
public class ExportCommands
[CommandMethod("ExportBlocksToPNG")]
public static void ExportBlocksToPNG()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
string outputDir = GetOutputDirectory(ed);
if (string.IsNullOrEmpty(outputDir)) return;
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
foreach (ObjectId btrId in bt)
BlockTableRecord btr = tr.GetObject(btrId, OpenMode.ForRead) as BlockTableRecord;
if (ShouldSkipBlock(btr)) continue;
try
ExportBlockAsImage(btr, db, outputDir, ed);
catch (Exception ex)
ed.WriteMessage($"\n错误:导出块 {btr.Name} 失败 - {ex.Message}");
tr.Commit();
private static string GetOutputDirectory(Editor ed)
var pso = new PromptStringOptions("\n请输入输出目录路径:")
AllowSpaces = true,
UseDefaultValue = true,
DefaultValue = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments)
return ed.GetString(pso).StringResult;
private static bool ShouldSkipBlock(BlockTableRecord btr)
return btr.IsLayout || btr.Name.StartsWith("*") ||
btr.IsFromExternalReference || btr.Name.Equals("_ADESK_BLOCK");
private static void ExportBlockAsImage(BlockTableRecord btr, Database db, string outputDir, Editor ed)
string layoutName = $"TEMP_{Guid.NewGuid():N}";
LayoutManager.Current.CreateLayout(layoutName);
using (var tr = db.TransactionManager.StartTransaction())
var layout = (Layout)tr.GetObject(
LayoutManager.Current.GetLayoutId(layoutName),
OpenMode.ForWrite);
try
// 创建并配置 PlotSettings
PlotSettings ps = new PlotSettings(layout.ModelType);
ps.CopyFrom(layout);
PlotSettingsValidator psv = PlotSettingsValidator.Current;
// 设置打印机和纸张
if (!SetPlotterConfiguration(psv, ps, "PublishToWeb PNG.pc3", ed))
return;
// 设置打印范围和类型
psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Window);
SetPlotWindow(psv, ps, btr, db);
// 创建 PlotConfig 并设置输出参数
PlotConfig plotConfig = PlotConfig.CreateDefault();
plotConfig.ApplyFromPlotSettings(ps); // 从 PlotSettings 导入配置
plotConfig.PlotToFile = true; // 启用文件输出
plotConfig.OutputFileName = GetOutputFileName(btr, outputDir); // 设置文件名
// 创建 PlotInfo
PlotInfo plotInfo = new PlotInfo();
plotInfo.Layout = layout.ObjectId;
// 执行打印
ExecutePlot(db, plotInfo, plotConfig, ed);
finally
LayoutManager.Current.DeleteLayout(layoutName);
tr.Commit();
private static bool SetPlotterConfiguration(PlotSettingsValidator psv, PlotSettings ps, string configName, Editor ed)
try
psv.SetPlotConfigurationName(ps, configName, null);
return true;
catch
ed.WriteMessage($"\n错误:找不到打印机配置 {configName}");
return false;
private static void SetPlotWindow(PlotSettingsValidator psv, PlotSettings ps, BlockTableRecord btr, Database db)
using (var tempRef = new BlockReference(Point3d.Origin, btr.ObjectId))
Extents3d extents = tempRef.GeometricExtents;
psv.SetPlotWindowArea(ps, new Extents2d(
new Point2d(extents.MinPoint.X, extents.MinPoint.Y),
new Point2d(extents.MaxPoint.X, extents.MaxPoint.Y)));
tr.Commit();
private static string GetOutputFileName(BlockTableRecord btr, string outputDir)
string safeName = Path.GetInvalidFileNameChars()
.Aggregate(btr.Name, (current, c) => current.Replace(c, '_'));
return Path.Combine(outputDir, $"{safeName}.png");
private static void ExecutePlot(Database db, PlotInfo plotInfo, PlotConfig plotConfig, Editor ed)
using (PlotEngine plotEngine = PlotFactory.CreatePublishEngine())
using (PlotProgressDialog progress = new PlotProgressDialog(false, 1, false))
plotEngine.BeginPlot(progress, null);
plotEngine.BeginDocument(plotInfo, db.Filename, null, 1, true, plotConfig.OutputFileName);
PlotPageInfo pageInfo = new PlotPageInfo();
plotEngine.BeginPage(pageInfo, plotInfo, true, null);
plotEngine.BeginGenerateGraphics(null);
plotEngine.EndGenerateGraphics(null);
plotEngine.EndPage(null);
plotEngine.EndDocument(null);
plotEngine.EndPlot(null);
ed.WriteMessage($"\n成功导出:{plotConfig.OutputFileName}");
