C# AutoCAD drawing file write protection errors in Batch loop.
muckmailer
muckmailer
The following batch loop will work for as far as pulling up a group of drawings and saving them
when the  sample routine  "public static void AddCircle()" is flagged out. When I try to make drawing
changes using routine public static void AddCircle() the DrawingSaved routine give me drawing write
protection errors. How can I avoid drawing write protections errors in my batch loop.
//CODE
        private void button5_Click(object sender, EventArgs e)
            //Loop through each item in the array
            //foreach (string myStr in thisFormsArray)
            BatchLoop();
  //Batch loop to open close drawings
       public void BatchLoop()
            foreach (String myStr in thisFormsArray)
                MessageBox.Show(myStr);
                // Open the Drawing
                strFileName = myStr;
                OpenDrawing();
                //Add Drawing Changes code here.
                AddCircle();// My Sample Routine
                DrawingSaved();
                Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                //Close drawing
                doc.CloseAndDiscard();
        public static void DrawingSaved()
                //Savedwg
                object obj = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("DBMOD");
            // Check the value of DBMOD, if 0 then the drawing has no unsaved changes
            if (System.Convert.ToInt16(obj) != 0)
                if (System.Windows.Forms.MessageBox.Show("Do you wish to save this drawing?",
                                          "Save Drawing",
                                          System.Windows.Forms.MessageBoxButtons.YesNo,
                                          System.Windows.Forms.MessageBoxIcon.Question)
                                          == System.Windows.Forms.DialogResult.Yes)
                    Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                    acDoc.Database.SaveAs(acDoc.Name, true, DwgVersion.Current,
                                          acDoc.Database.SecurityParameters);
           public void OpenDrawing()
           // strFileName = "C:\\campus.dwg";
                        //string strFileName = myStr;
            DocumentCollection acDocMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
            //Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            if (File.Exists(strFileName))
                //acDocMgr.Open(strDwgName, false);
                DocumentCollectionExtension.Open(acDocMgr, strFileName);
            else
                acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " + strFileName +
                                                               " does not exist.");
          // public static void AddCircle(Document acDoc)
           public static void AddCircle()// My sample code
               // Get the current document and database
              // Document acDoc = Application.DocumentManager.MdiActiveDocument;
               Database acCurDb = acDoc.Database;
               using (DocumentLock docLock = acDoc.LockDocument())
               // Start a transaction
                   using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                       // Open the Block table for read
                       BlockTable acBlkTbl;
                       acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
                                                       OpenMode.ForRead) as BlockTable;
                       // Open the Block table record Model space for write
                       BlockTableRecord acBlkTblRec;
                      //Here******************************************************************
                       acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
                                                       OpenMode.ForWrite) as BlockTableRecord;
                        //Heres
                       // Create a circle that is at 2,3 with a radius of 4.25
                       using (Circle acCirc = new Circle())
                           acCirc.Center = new Point3d(2, 3, 0);
                           acCirc.Radius = 4.25;
                           // Add the new object to the block table record and the transaction
                           acBlkTblRec.AppendEntity(acCirc);
                           acTrans.AddNewlyCreatedDBObject(acCirc, true);
                       // Save the new object to the database
                       acTrans.Commit();
                   }// for lockdocument
augusto.goncalves
Call Database.CloseInput and make sure you Dispose the Database variable when you're done (try the 'using' keyword)
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
muckmailer
I have modified and cleaned my code.
As of now I can generate new drawings but I can't overwrite existing drawings.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
// Added for Autocad
//using Autodesk.AutoCAD.Interop.AcadDocument;
using Autodesk.AutoCAD.Interop;
namespace MyAcadCSharpPlugin1
public partial class Form1 : Form
public Form1()
InitializeComponent();
private string strFileName;
private string strDwgName;
private string[] thisFormsArray;
public string[] myArray
get
return thisFormsArray;
set
thisFormsArray = value;
private void button1_Click(object sender, EventArgs e)
FormDialog FormDialog = new FormDialog();
Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(FormDialog);
//on form2:
//create a method to show content of array:
public void ShowingArray(string[] array)
//1. or to pass to some control:
foreach (string item in array)
listBox1.Items.Add(item);
//2. or to show in meesageBox (or similar):
StringBuilder sb = new StringBuilder();
sb.AppendLine(item);
MessageBox.Show(sb.ToString());
private void Form1_Load(object sender, EventArgs e)
//Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
private string[] StArray;
private void button4_Click(object sender, EventArgs e)
ListDrawings();
public void ListDrawings()
listBox1.Items.Clear();
listBox1.Items.Add(myStr);
public void DrawingChangeRoutine()
MessageBox.Show("Code Here");
// SetLayerCurrent();
//Posted
BatchLoop();
// Open the Drawing
OpenDrawing();
AddCircle();//Sample code routine to add circle in model space
//DrawingSaved();
SaveActiveDrawing1();
//Close drawing
public static void SaveActiveDrawing1()
int StrSaveNameLgh;
string strDWGName = acDoc.Name;
string StrSaveName;
string StrFileName;
string StrPathName;
String StrPath;
object obj = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("DWGTITLED");
//' Check to see if the drawing has been named
if (System.Convert.ToInt16(obj) == 0)
//' If the drawing is using a default name (Drawing1, Drawing2, etc)
//' then provide a new name
strDWGName = "c:\\MyDrawing1.dwg";
StrPathName = strDWGName;
StrPathName = StrPathName.Remove(StrPathName.Length - 4, 4);
StrFileName = Path.GetFileName(strDWGName);
StrSaveName = StrPathName + "\\" + "New-" + StrFileName;
MessageBox.Show(StrSaveName);
acDoc.Database.SaveAs(StrSaveName, true, DwgVersion.Current, acDoc.Database.SecurityParameters);
//acDoc.Database.SaveAs(strDWGName, true, DwgVersion.Current, acDoc.Database.SecurityParameters);
else
public static void AddCircle()//Sample code routine to add circle in model space
acTrans.Commit();
}// for lock document
using System;
using System.Data;
using System.Linq;
using System.Text;
using System.IO;
public Form1()
get
set
//on form2:
ListDrawings();
//Posted
BatchLoop();
// Open the Drawing
OpenDrawing();
//DrawingSaved();
//Close drawing
int StrSaveNameLgh;
string StrSaveName;
string StrFileName;
string StrPathName;
String StrPath;
else
acTrans.Commit();
arcticad
using System;
using System.Linq;
using System.Text;
using System.IO;
namespace CopyFile
    class clsCopyFile
        internal void ProcessFile(string strFullPath)
            // This has been my work around for a long long time.
            // Autocad may lock the file in use so we can do our processing in a copy and
            // then write the file back when finished, as long as the file is not already in use.
            // this will leave a copy in the temp folder.
            // the temp file will be locked until you close AutoCAD.
            string strNewFullPath = "";
            // Copy File to Temp
            if (!IsFileinUse(strFullPath))
                Copyfile(strFullPath, ref strNewFullPath);
                // Process File
                //  Write File back
                Copyfile(strNewFullPath, ref strFullPath);
            else
                System.Windows.Forms.MessageBox.Show("Unable to Process file :" + strFullPath);
        /// <summary>
        /// Copy File that can be in use
        /// </summary>
        /// <param name="strFullPath"></param>
        /// <param name="strNewFullPath"></param>
        /// <returns></returns>
        public bool Copyfile(string strFullPath, ref string strNewFullPath)
            try
                strNewFullPath = System.IO.Path.GetTempFileName() + ".dwg";
                using (var inputFile = new FileStream(strFullPath, FileMode.Open, FileAccess.Read, FileShare.ReadWrite))
                    using (var outputFile = new FileStream(strNewFullPath, FileMode.Create))
                        var buffer = new byte[0x10000];
                        int bytes;
                        while ((bytes = inputFile.Read(buffer, 0, buffer.Length)) > 0)
                            outputFile.Write(buffer, 0, bytes);
            catch (System.Exception)
                return false;
            return true;
        internal bool IsFileinUse(string path)
            try
                //Just opening the file as open/create
                using (FileStream fs = new FileStream(path, FileMode.OpenOrCreate))
                    //If required we can check for read/write by using fs.CanRead or fs.CanWrite                                 }
                    return false;
            catch (IOException)
                return true;
(defun botsbuildbots() (botsbuildbots))
augusto.goncalves
Seems like you're missing the CloseInput... without that, AutoCAD will maintain the .dwg file locked.
Or you may try SaveAs and the replace, as described at http://adndevblog.typepad.com/autocad/2012/04/batch-process-in-memory-1.html
Augusto Goncalves
