Bug when successively launching a function I've created
m.chavet7MJRB
m.chavet7MJRB
I've created a function in the following C# code that lets me import a shapefile into Civil 3D with object data.
When I run this command for the first time, it works without a hitch. When I run it a second time, the launching is interrupted.
The exception is as follows:
System.NullReferenceException: 'Object reference not set to an instance of an object.'
And occurs on the following line:
importer.Init("SHP", shpFiles);
[CommandMethod("AEPImportShape")]
public void AEPImportShape()
    Stopwatch sw = new Stopwatch();
    sw.Start();
    MapApplication mapApp = HostMapApplicationServices.Application;
    using (Importer importer = mapApp.Importer)
        Autodesk.AutoCAD.Windows.OpenFileDialog ofd = new Autodesk.AutoCAD.Windows.OpenFileDialog("Select Shapefile", null,
            "shp", "Select shp", Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowAnyExtension);
        if (ofd.ShowDialog() == System.Windows.Forms.DialogResult.OK)
            try
                //Array.Sort(shpFiles);
                string shpFiles = ofd.GetFilenames()[0];
                importer.Init("SHP", shpFiles);      //!!!!!!!!!!!!!!THE PROBLEM OCCURS HERE!!!!!!!!!!!!!!!!!!!
                string fileName = Path.GetFileNameWithoutExtension(shpFiles).Replace(" ", "");
                foreach (InputLayer inputLayer in importer)
                    inputLayer.SetLayerName(LayerNameType.LayerNameDirect, fileName);
                    inputLayer.SetDataMapping(ImportDataMapping.NewObjectDataOnly, fileName);
                    //inputLayer.Dispose();
                importer.ImportPolygonsAsClosedPolylines = true;
                ImportResults result = importer.Import(true);
                sw.Stop();
                importer.Dispose();
                dynamic acadApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
                acadApp.ZoomExtents();
            catch
                sw.Stop();
                importer.Dispose();
Anton_Huizinga
If you debug the code, what is shpFiles before you use it? Null?
ActivistInvestor
Did You try stepping through the code to find out what variable is null?
fieldguy
I decided to try this because I already had your code from your post in the map developer forum (which is where this post belongs as well IMO).
I believe the problem is "ofd" but it is definitely not null (System.IO.File.Exists(ofd.Filename) is true).
For some reason, the managedmapapi does not like it.
Try separating your "ofd" out of the "import" method - something like this:
[CommandMethod("SHP2")]
static public void SHP2()
          "Select SHP File", null, "shp", "Select shp", Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowAnyExtension);
      if (ofd.ShowDialog() == DialogResult.OK)
          string shpname = ofd.Filename;
          Import2(shpname);
}//acad command - SHP2
private static void Import2(string shpname)
    string fname = Path.GetFileNameWithoutExtension(shpname).Replace(" ", "");
    Importer importer = mapApp.Importer;
    try
        importer.Init("SHP", shpname);
        foreach (InputLayer il in importer)
            il.SetLayerName(LayerNameType.LayerNameDirect, fname);
            il.SetDataMapping(ImportDataMapping.NewObjectDataOnly, fname);
        }// foreach shp layer
        ImportResults ir = importer.Import(true);
    catch { }
    finally { };
}// Import2
