beginner tip
beginner tip
beginner tip
Well guys, I'm sorry for this question , but there is an way to learn how to read the documentation of the .net into objectARX? for example, If I work with RibbonButtons, where can I find an explanation of each parameter into that class like, Text, Showtext?  I tried to find those parameters of the class into the 'arxdoc'?
Thanks in advance.
Virupaksha_aithal
Autodesk Support
Autodesk Support
Thanks for the question.
Not all the API exposed in .NET will be available in C++. Ribbons are one such API. Ribbons are .NET only API.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
5thSth
you can find help files in .doc folder of your "ObjectArx" folder - arxmgd file.
depends on your install location.
