Background mask for Multiline Attribute In Block
brianchapmandesign
brianchapmandesign
This doesn't seem to turn on the background mask for a multiline attribute in a block. Anyone know what will?
BlockReference blkRef = (BlockReference)tr.GetObject(blkId, OpenMode.ForRead);
                            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead);
                            AttributeCollection attCol = blkRef.AttributeCollection;
                            foreach (ObjectId attId in attCol)
                                AttributeReference attRef = (AttributeReference)tr.GetObject(attId, OpenMode.ForRead);
                                if (attRef.IsMTextAttribute)
                                    btr.UpgradeOpen();
                                    attRef.UpgradeOpen();
                                    attRef.MTextAttribute.BackgroundFillColor = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.None, 198);
                                    attRef.MTextAttribute.UseBackgroundColor = false;
                                    attRef.UpdateMTextAttribute();
                                    blkRef.RecordGraphicsModified(true);
"Very funny, Scotty. Now beam down my clothes.
_gile
                                    btr.UpgradeOpen();
Just having a quick look at your code, did you try with true instead?
attRef.MTextAttribute.UseBackgroundColor = true;
Gilles Chanteau
GileCAD
GitHub
brianchapmandesign
Thanks Gile, I did 😕 Appears to not work either.
ActivistInvestor
Here is the source for the AttributeReference.MTextAttribute property:
// Autodesk.AutoCAD.DatabaseServices.AttributeReference
public MText MTextAttribute
	get
		IntPtr unmanagedObjPtr = new IntPtr(<Module>.AcDbAttribute.getMTextAttribute(this.GetImpObj()));
		return new MText(unmanagedObjPtr, false);
	set
		int num = (int)<Module>.AcDbAttribute.setMTextAttribute(this.GetImpObj(), value.GetImpObj());
		if (num != 0)
			throw new Autodesk.AutoCAD.Runtime.Exception((ErrorStatus)num);
Each use of that property produces a new MText managed wrapper. The wrapper is not stored by the AtttribueReference, and it doesn't know or care what you do with it, other than that it must be disposed.
When you do this:
 attRef.MTextAttribute.BackgroundFillColor = Autodesk.AutoCAD.Colors... blah blah blah
you are assigning the value of one property to each of two different MText objects.
You instead have to do this:
 MText mtext = attRef.MtextAttribute;
 mtext.BackgroundFillColor = Autodesk.AutoCAD.Colors... blah blah blah
 mtext.UseBackgroundColor = true;
 attRef.MtextAttribute = mtext;
                                    btr.UpgradeOpen();
brianchapmandesign
Thank you both
