Autoloader doesn't - unknown command
kstate92
Message 1 of 13
kstate92
Package Contents.pngI've resigned myself to using the Appload / Startup Suite / lsp file workaround to get my project to load on startup, as I cannot understand why the autoload function doesn't.  The last thing I changed was switching from LoadonAutoCADStartup to LoadOnCommandInvocation and the required  Commands / Command nodes.  Using the Startup lisp routine, the project loads and runs when the command name 'partslist' is entered.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Replies (12)
Message 2 of 13
moogalm
Autodesk Support
Autodesk Support
Sorry, I didn't understand your query correctly, can you please explain what is working for you and what is n't ?
Message 3 of 13
kstate92
Even with the bundle folder structure and the xml file shown in my first post, when I invoke the routine (Command Method), I get 'unknown command'.
My plugin runs fine if I first manually netload the dll from the projects' folder bundle placed in C:\ProgramData\Autodesk\ApplicationPlugins, or if I add a netload lisp file to the appload Startup Suite.
KState92
Quadro P2000
Message 4 of 13
moogalm
Autodesk Support
Autodesk Support
Can you please share Bundle structure XML ?, no need of your .NET dll, I will create my own helloworld sample.
Message 5 of 13
TimB67530
Message 6 of 13
Alexander.Rivilis
@TimB67530 wrote:
It is look like empty zip-file. 😞
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 7 of 13
TimB67530
Oh, FFS...
Added files (I hope).
Message 8 of 13
Alexander.Rivilis
What about replace:
ModuleName="./Contents/PartsList.dll"
with
ModuleName="./Contents/Resources/PartsList.dll"
and
SupportPath="./Contents/Resouces"
with
SupportPath="./Contents/Resources"
Expert Elite Member
Message 9 of 13
TimB67530
@Alexander.Rivilis wrote:
What about replace:
with
and
with
First an empty zip file, then overlooking two childish mistakes...
There must be a third one, as it still comes back with Unknown Command.
Corrections attached.
Message 10 of 13
Alexander.Rivilis
Repeat please:
Expert Elite Member
Message 11 of 13
Alexander.Rivilis
Test with this attached bundle. Do not forget to unblock the zip-file!!!
Command PartsList have to be working.
Expert Elite Member
Message 12 of 13
Alexander.Rivilis
Expert Elite Member
Message 13 of 13
TimB67530
THIRD DUMB MISTAKE FOUND: I forgot I had re-named the actual dll filename during all my various amateur attempts.
I changed it back to match the xml file and it loads on command entry.
Thank you very much, Alexander.
