Autodesk.Autocad.Runtime.Exception: eFileSystemErr
AutoCAD 2020 / Vollversion
Visual Studio 17
Zielframework: .Net Framework 4.7
Good Morning,
I have older .Net programs that I would now like to
make suitable for Autocad 2020, so far so good.
Before the program starts I get an error message
Autodesk.Autocad.Runtime.Exception: eFileSystemErr.
Code line 56 in myCommand, see attachment.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.Runtime
'<Assembly: CommandClass(GetType(HI_STAHL_VKR.myCommands))>
Namespace HI_Stahl_VKR
Public Class MyCommands
<CommandMethod("HI:VKR")>
Public Sub HIVKR()
Dim acDoc As Document = DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction
Try
Dim acLineTypTable As LinetypeTable = acTrans.GetObject(acCurDb.LinetypeTableId, OpenMode.ForRead)
Dim myCONTINUOUS As String = "Continuous"
If acLineTypTable.Has(myCONTINUOUS) = False Then
                        acCurDb.LoadLineTypeFile(myCONTINUOUS, "acad.lin")
AutoCAD 2020 / full version
Visual Studio 17
Target framework: .Net Framework 4.7
Does anyone have any idea what that might be?
Thanks in advance.
Good Morning,
for whatever reason the "acad.lin" was not found although the
support path was / is entered under Options.
I have now implemented it and now everything works again without
an error message.
Dim LinPath = Environment.GetFolderPath(Environment.SpecialFolder.UserProfile)
LinPath &= "\AppData\Roaming\Autodesk\AutoCAD 2020\R23.1\deu\Support"
Dim acadlin As String = New IO.DirectoryInfo(LinPath).GetFiles("acad.lin").ToString
If acLiTypTbl.Has("STRICHPUNKT") = False Then
   acCurDb.LoadLineTypeFile("STRICHPUNKT", acadlin)
   acTrans.Commit()
Alexander.Rivilis
What about using HostApplicationServices.FindFile?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
