Autodesk.AutoCAD.Runtime.Exception:“eAlreadyInDb” happened at code “blockTableRecord.AppendEntity(entity);”
1755384511
1755384511
I  want to create  a block from some selected entities,
here is the code :
MAIN FUNCTION:
public class _ExtensionTest_{
 [CommandMethod(nameof(BlockCreateTEST023))]
  public void BlockCreateTEST023()
      //AddEntityByDB aedb = new AddEntityByDB();
      Database database = HostApplicationServices.WorkingDatabase;
      Document document = Application.DocumentManager.MdiActiveDocument;
      Editor editor = document.Editor;
      String blockName = "BLOCK0001";
      var ccIds = document.SelectEntity().GetObjectIds() ;
      editor.WriteMessage($"{string.Join("+\n", ccIds)}  \n");
      var resID = ccIds.ToBlockTable(blockName);
      editor.WriteMessage($"resID:{resID}  ");
HELPER CODE:
public  static class BlockExtension
  public static SelectionSet SelectEntity(this Document document, SelectionFilter selectionFilter = null)
      PromptSelectionResult promptSelRes = editor.SelectImplied();
      ObjectId[] emptyObjectId = new ObjectId[0];
      editor.SetImpliedSelection(emptyObjectId);
      if (promptSelRes.Status != PromptStatus.OK)
          if (selectionFilter == null)
              promptSelRes = editor.GetSelection();
          else
              promptSelRes = editor.GetSelection(selectionFilter);
      SelectionSet selectionSet = null;
      if (promptSelRes.Status == PromptStatus.OK)
          selectionSet = promptSelRes.Value;
          editor.WriteMessage($"selected num :{selectionSet.Count.ToString()}");
      else
          editor.WriteMessage($"selected num :0");
      return selectionSet;
public  static class ObjectExtension
 public static ObjectId ToBlockTable(this IEnumerable<ObjectId> objectIds, string blockName)
     var database =  HostApplicationServices.WorkingDatabase;
     ObjectId btrId = ObjectId.Null;
     using (Transaction trans = database.TransactionManager.StartTransaction())
         BlockTable bt = (BlockTable)database.BlockTableId.GetObject(OpenMode.ForWrite);
         if (bt.Has(blockName)) { btrId = bt[blockName]; }
         if (!bt.Has(blockName))
             using (BlockTableRecord btr = new BlockTableRecord() { Name = blockName })
                 foreach (var objectId in objectIds)
                     Entity ent = trans.GetObject(objectId, OpenMode.ForRead, true) as Entity;
                     if (ent == null) continue;
                     btr.AppendEntity(ent);
                 btrId = bt.Add(btr);
                 trans.AddNewlyCreatedDBObject(btr, true);
             trans.Commit();
     return btrId;
I selected three circles created by handle , then I got an ERROR IT SAYS :
 Autodesk.AutoCAD.Runtime.Exception: eAlreadyInDb
在 Autodesk.AutoCAD.DatabaseServices.BlockTableRecord.AppendEntity(Entity entity)
在 SEPD.ACAD.Extension.BlockExtension.ToBlockTable(IEnumerable`1 objectIds, String blockName) 位置 D:\WORKSPACE\CODE_CAD\SEPD.ACAD.Extension\SEPD.ACAD.Extension\BlockExtension.cs:行号 226
在 SEPD.ACAD.Extension._ExtensionTest_.BlockCreate023() 位置 D:\WORKSPACE\CODE_CAD\SEPD.ACAD.Extension\SEPD.ACAD.Extension\_ExtensionTest_.cs:行号 645
在 Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
在 Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
在 Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
在 Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
seems some problem heppend at code "btr.AppendEntity(ent)"
TIP:
If I quit use the SelectEntity Function , just create circle by code , then , everything is fine;
_gile
The entities you're trying to add to the block definition (BlockTableRecord) are already owned by the BlockTableRecord of the space in which you selected them.
You have to create a copy (clone) of each selected entity and append these clones to the block definition.
public static ObjectId ToBlockTableRecord(this IEnumerable<ObjectId> objectIds, string blockName)
        BlockTable bt = (BlockTable)trans.GetObject(database.BlockTableId, OpenMode.ForRead);
        // if the block definition already exists in the block table, return its ObjectId
            return bt[blockName];
        // Create a new block definition
        trans.GetObject(database.BlockTableId, OpenMode.ForWrite);
        var btr = new BlockTableRecord() { Name = blockName };
        var btrId = bt.Add(btr);
        // Deep clone each entity in the block definition
        var mapping = new IdMapping();
        database.DeepCloneObjects(new ObjectIdCollection(objectIds.ToArray()), btrId, mapping, false);
        trans.Commit();
        return btrId;
Gilles Chanteau
GileCAD
GitHub
Nice job, I have succeeded, many thanks!
