AUTOCAD .NET BLOCK COUNT TABLE
cihanbaki2147
Message 1 of 13
cihanbaki2147
AUTOCAD .NET  BLOCK  COUT  LİST  İNSERT  TABLE  CEL.
Document doc = AcAp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
string[] blokcneme = new string[3];
blokcneme[0] = "name1.dwg";
blokcneme[1] = "name2.dwg";
blokcneme[2] = "name3.dwg";
TypedValue[] filter =
new TypedValue( (int)DxfCode.Operator, "<or"),
new TypedValue((int)DxfCode.Start, "INSERT"),
new TypedValue( (int)DxfCode.Operator,"<and"),
new TypedValue((int)DxfCode.BlockName,blokcneme[0]),
new TypedValue((int)DxfCode.Operator, "and>" ),
new TypedValue((int)DxfCode.BlockName,blokcneme[1]),
new TypedValue((int)DxfCode.BlockName,blokcneme[2]),
new TypedValue( (int)DxfCode.Operator,"or>")
// Prompt the user for a selection
PromptSelectionResult psr = ed.GetSelection(new SelectionFilter(filter));
if (psr.Status != PromptStatus.OK) return;
SelectionSet ss = psr.Value;
string blokname = "";
int cout= 0;
using (Transaction tr = db.TransactionManager.StartTransaction())
foreach (ObjectId brId in psr.Value.GetObjectIds())
BlockReference br = (BlockReference)tr.GetObject(brId, OpenMode.ForRead);
cout = psr.Value.Count;
blokname += br.Name.ToString()+"cout"+cout.ToString();
ed.WriteMessage( blokname);
tr.Commit();
Replies (12)
Message 2 of 13
_gile
It seems like you want to run before you know how to walk.
You should learn the basics of the AutoCAD .NET API with simpler tasks.
for example, concerning selection sets, you should read this topic and more accurately about selection sets this one.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 13
cihanbaki2147
I want to list the mores and names of the blocks in the drawing so I know the autocad selection sessions and filtering processes.
Message 4 of 13
_gile
Did you try your code to select blocks?
It seems to me it can't work. You confuse block name and block file name (with .dwg extension) which won't work in a selection filter,  and you selection filter contains many superfluous expressions.
You can try the following code.
        [CommandMethod("BLKCNT")]
        public static void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var filter = new SelectionFilter(new[] {
                new TypedValue(0, "INSERT"),
                new TypedValue(2, "name1,name2,name3") });
            var psr = ed.GetSelection(filter);
                return;
                var ppr = ed.GetPoint("\nSpecify the table insertion point: ");
                if (ppr.Status != PromptStatus.OK)
                    return;
            using (var tr = db.TransactionManager.StartTransaction())
                var blocks = psr.Value
                    .Cast<SelectedObject>()
                    .Select(so => (BlockReference)tr.GetObject(so.ObjectId, OpenMode.ForRead))
                    .GroupBy(br => br.Name)
                    .ToDictionary(gr => gr.Key, gr => gr.ToArray());
                double rowHeight = 9.0;
                double colWidth = 50.0;
                var table = new Table();
                table.TableStyle = db.Tablestyle;
                table.Cells[0, -1].Style = "_TITLE";
                table.Columns[0].Width = colWidth;
                table.InsertRows(1, rowHeight, blocks.Count + 1);
                table.InsertColumns(1, colWidth, 2);
                table.Cells[0, 0].Value = "BLOCK DATA";
                table.Cells[1, 0].Value = "PREVIEW";
                table.Cells[1, 1].Value = "BLOCK NAME";
                table.Cells[1, 2].Value = "COUNT";
                int row = 2;
                foreach (var entry in blocks)
                    table.Cells[row, 0].BlockTableRecordId = entry.Value[0].BlockTableRecord;
                    table.Cells[row, 1].Value = entry.Key;
                    table.Cells[row, 2].Value = entry.Value.Length;
                    row++;
                table.Position = ppr.Value;
                table.TransformBy(ed.CurrentUserCoordinateSystem);
                var cSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                cSpace.AppendEntity(table);
                tr.AddNewlyCreatedDBObject(table, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 5 of 13
fsl88
Thanks for this. Im having an error in
Error 4 'Autodesk.AutoCAD.EditorInput.SelectionSet' does not contain a definition for 'Cast' and no extension method 'Cast' accepting a first argument of type 'Autodesk.AutoCAD.EditorInput.SelectionSet' could be found (are you missing a using directive or an assembly reference?)
Message 6 of 13
_gile
Try like this:
var blocks = psr.Value.GetObjectIds()
    .Select(id => (BlockReference)tr.GetObject(id, OpenMode.ForRead))
Gilles Chanteau
GileCAD
GitHub
Message 7 of 13
fsl88
thanks its compiling good. but when I tried it , its saying "0 found" when im window selecting on acad.
Message 8 of 13
_gile
Show your code.
Gilles Chanteau
GileCAD
GitHub
Message 9 of 13
fsl88
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using System.Data;
using System.Windows;
using System.IO;
using System.Collections.Generic;
using System.Text;
using System.Linq;
namespace BLOCKCOUNT
public class Class1
return;
return;
/*var blocks = psr.Value
.ToDictionary(gr => gr.Key, gr => gr.ToArray());*/
int row = 2;
row++;
tr.Commit();
Message 10 of 13
_gile
Does your drawing contains blocks named name1 or name2 or name3? because the selection filter only search for these block names.
You should not just copy/paste codes you do not understand, this is the worst way to learn.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 13
essam-salah
Hi @_gile
what is the difference between these filters
                new TypedValue(-4, "<or"),
                new TypedValue(2, "name1"),
                new TypedValue(2, "name2"),
                new TypedValue(2, "name3"),
                new TypedValue(-4, "or>"),
                new TypedValue(-4, "<and"),
                new TypedValue(-4, "and>"),
Message 12 of 13
_gile
They work the same way, some are just most verbose.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 13
essam-salah
@_gile i was confused, thanks for clearing that up.
