Autocad map DisplayFeatures error
Sgear
Sgear
Hi
when I check in drawing for classified entity and total and length I don't get error but somtime Autocad crash
This is what I see in Autocad dumpdata
Clr Data:
at Autodesk.AutoCAD.DatabaseServices.Transaction.DeleteUnmanagedObject()
at Autodesk.AutoCAD.Runtime.DisposableWrapper.!DisposableWrapper()
at Autodesk.AutoCAD.Runtime.DisposableWrapper.Dispose(Boolean A_0)
GDI_Objects:1857 User_Objects:929 Process_Handles:1878]]>
Regards
       Public Sub DisplayFeatures(ByVal sl_tegind)
            Dim errorCode As Classification.FeatureClassErrorCode = Classification.FeatureClassErrorCode.OK
            Try
                Dim colIds As ObjectIdCollection = Nothing
                Dim total As String
                Dim PipelineLength As Double
                Dim dbObj As DBObject
                Dim ent As Entity = Nothing
                Dim trans As Transaction = Nothing
                Dim Classtype As String
                Try
                    Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                    Dim AcApp As Autodesk.AutoCAD.Interop.AcadApplication = DirectCast(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, Autodesk.AutoCAD.Interop.AcadApplication)
                    Dim ThisDrawing As Autodesk.AutoCAD.Interop.AcadDocument = AcApp.ActiveDocument
                    Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                    Dim dd As Editor = doc.Editor
                    Dim ed As Autodesk.AutoCAD.EditorInput.Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
                    Classtype = sl_tegind
                    colIds = m_ClassificationManager.GetClassifiedEntities(Classtype.ToString(), True)
                    total = colIds.Count.ToString
                Catch e As System.Exception
                    '  Utility.ShowMsg(vbNewLine & "No classified entity." & vbNewLine)
                 '   AddElementToStringArray(tegund & "," & "0" & "," & "0")
                    Return
                End Try
                Dim colId As ObjectId
                For Each colId In colIds
                    trans = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
                    ent = trans.GetObject(colId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead)
                    dbObj = trans.GetObject(colId, OpenMode.ForWrite)
                    Dim l As Polyline = DirectCast(dbObj, Polyline)
                    PipelineLength = PipelineLength + l.Length.ToString
                Next colId
                AddElementToStringArray(Classtype & "," & total & "," & PipelineLength)
                Utility.ShowMsg(vbNewLine & Classtype)
                Utility.ShowMsg(vbNewLine & total)
                Utility.ShowMsg(vbNewLine & PipelineLength)
                trans.Commit()
                trans.Dispose()
            Catch err As MapFeatureClassException
                errorCode = err.ErrorCode
            Finally
            End Try
            If errorCode <> Classification.FeatureClassErrorCode.OK Then
                Utility.ShowMsg(vbNewLine & "Display ClassifiedEntities failed. Error code: ")
                Utility.ShowMsg(String.Concat(GetPrintErrorMessage(errorCode), vbNewLine))
            Else
        End Sub
norman.yuan
If you take closer llok at this code snippet of yours:
                Next colId
                trans.Commit()
                trans.Dispose()
Your code starts a number of Transactions inside the For Each...Next. and you only Commit() and Dispose() the last Transaction when the For Each...Next loop is done.That means your code leave many Transactions not disposed. This explains the exception message you get. And depending on how many loops the For Each...Next has to go through, at certain point AutoCAD simply cannot handle too many Transactions left hanging on, so, your code crashes from time to time.
You should start a single Transaction with a Using...End Using block (or a Try..Catch...Finally with Transaction.Dispose() in the Finally clause) that wraps the For Each...Next loop inside.
Norman Yuan
Drive CAD With Code
Sgear
Thanks will go over this to day
Regards
