AutoCAD crashes by using ObjectAppended only with some entities
MGOMKD
MGOMKD
Hi all,
I would like to re-encode my plug-in lighter, in order to optimize tasks.
So I would like to store dynamically, in an ArrayList or else, entities properties (ID, Layer, Bounds...etc.) by using reactors.
It works! but not with every entity! For instance AutoCAD crashes when I create a CIRCLE while ObjectAppended is invoking.
Here is a simply code to resume:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Public Class Class1
    Friend acDoc As Document = Application.DocumentManager.MdiActiveDocument
    Friend acCurDb As Database = acDoc.Database
    Friend ed As Editor = acDoc.Editor
    <CommandMethod("Test")> _
    Public Sub Test()
        AddHandler acCurDb.ObjectAppended, AddressOf MyDelegate
    End Sub
    Public Sub MyDelegate(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs)
        On Error Resume Next
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim acblktbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            Dim acblkTblRec As BlockTableRecord = acTrans.GetObject(acblktbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            For Each acObjId As ObjectId In acblkTblRec
                If acObjId = e.DBObject.ObjectId Then
                    Dim MyEnt As Entity = acTrans.GetObject(acObjId, OpenMode.ForRead)
                    Dim message As String = MyEnt.GetRXClass.DxfName.ToString & vbLf
                    Select Case MyEnt.GetRXClass.DxfName
                        Case Is = "LWPOLYLINE"
                            Dim Mypolyline As Polyline = CType(MyEnt, Entity)
                            message += "Area= " & Mypolyline.Area.ToString & vbLf
                            message += "Layer= " & Mypolyline.Layer.ToString & vbLf
                            message += "Min point= " & Mypolyline.Bounds.Value.MinPoint.ToString & vbLf
                            message += "Max point= " & Mypolyline.Bounds.Value.MaxPoint.ToString & vbLf
                        Case Is = "CIRCLE"
                            Dim Mycircle As Circle = CType(MyEnt, Circle)
                            message += "Area= " & Mycircle.Area.ToString & vbLf
                            message += "Calque= " & Mycircle.Layer.ToString & vbLf
                            message += "Radius= " & Mycircle.Radius.ToString & vbLf
                    End Select
                    MsgBox(message)
            Next
        End Using
    End Sub
End Class
 What can I do to solve that!?
I would imagine that this post would get more traction over in the customizations forums.
MGOMKD
Sure! But how could I put it in the right section, I mean .NET section!?
drjohn
Use the RIC (Report Inappropriate Content) selection on the left and ask and admin to move it for you.
DJ
MGOMKD
HI all,
I solved the problem by adding this line:
acTrans.Commit
AutoCAD now no longer crashes but another problem occurs when adding circles.
Specific properties (like center, circumference, radius, diameter) are initialized to 0, while those of other entities are well notified.
Here is the code:
Public Class Class1
    Public Sub Test()
    End Sub
                    Dim message As String = "Object: " & MyEnt.GetRXClass.DxfName.ToString & vbLf
                    message += "Layer= " & MyEnt.Layer.ToString & vbLf
                    message += "Color Index= " & MyEnt.ColorIndex.ToString & vbLf
                        Case Is = "ARC"
                            Dim Myarc As Arc = CType(MyEnt, Arc)
                            message += "Bounds Min point= " & Myarc.Bounds.Value.MinPoint.ToString & vbLf
                            message += "Bounds Max point= " & Myarc.Bounds.Value.MaxPoint.ToString & vbLf
                            message += "Center= " & Myarc.Center.ToString & vbLf
                            message += "Radius= " & Myarc.Radius.ToString
                        Case Is = "CIRCLE"
                            message += "Bounds Min point= " & Mycircle.Bounds.Value.MinPoint.ToString & vbLf
                            message += "Bounds Max point= " & Mycircle.Bounds.Value.MaxPoint.ToString & vbLf
                            message += "Center= " & Mycircle.Center.ToString & vbLf
                            message += "Diameter= " & Mycircle.Diameter.ToString & vbLf
                            message += "Circumference= " & Mycircle.Circumference
                            Dim Mypolyline As Polyline = CType(MyEnt, Polyline)
                            message += "Bounds Min point= " & Mypolyline.Bounds.Value.MinPoint.ToString & vbLf
                            message += "Bounds Max point= " & Mypolyline.Bounds.Value.MaxPoint.ToString & vbLf
                            message += "Length= " & Mypolyline.Length.ToString
                        Case Is = "XLINE"
                            Dim Myxline As Xline = TryCast(MyEnt, Xline)
                            message += "Handle= " & Myxline.Handle.ToString
                    End Select
                    MsgBox(message)
            Next
            acTrans.Commit()
        End Using
    End Sub
End Class
What's wrong with my code?
MGOMKD
Hi!
By looking in my code, does anyone knows why, while adding "Circle" in model space, it returns null specifics properties!?
