AutoCAD C# API Switch drawing event
Hello Guys,
 I am working on an application, where based on the template I am fetching data from database.
Now if the user open multiple drawings then if the user click on the tabs to swtich between templates how do it trigger an event to fetch data relevant to the current open drawing.
Thanks.
_gile
Hi
You should have a look at the DocumentCollection events: DocuementActivated, DocumentToBeActivated, DocumentToBeDeactivated.
Gilles Chanteau
GileCAD
GitHub
SanjoyNath
Dear Experts,
AdvanceSteel runs over Autocad. And Advance Steel dont have Document Collections (DocuementCollection) object.
When i call the Autocads DocuementCollection that dont load all features (Even the document is prepared with Advance Steel on Autocad and the file is dwg) If i open the same file with manual open then i get everything there
Why
Sanjoy Nath
BIM Manager And Digital Lead (Structures Online)
BOOST, AR , VR ,EPM,IFC API,PDF API , CAD API ,Revit API , Advance Steel API
Founder of Geometrifying Trigonometry(C)
